I am installing a wall furnace in a 2×6 wall instead of a 2×4 wall is it ok to put some 2 inch rigid insulation beetween the furnace and exterior wall? The instructions dont mention any clearance requirements for the backside.
Listeners write in about HVAC company consolidation and stains from supply lines and ask questions about Larsen trusses and insulating stucco houses.
I installed a wall furnace and mine could be flush mounted up against the wall. Or in your case rigid insulation. Check your owners manuel for details or if you don;t have one and its an older wall furnace, go on line to the manufactuer to be sure.
I recently installed a 35k BTU "blue flame" vent-free heater in a job i am working on for temp heat. It said that it could be flush mounted against a wall (although i was sceptical/cautious). I leave the thing running for 9 hours a day and the back doesnt get hot at all. the sides are barely warm - the top a little more. Nothing that would cause you a problem - though.
