Wall mount toilet installation.
I have two older Kohler wall mount toilets, (late 60’s from the colors)with round bowls I want to replace with Kohler Wellesleys with elongated bowls.
I have the two toilets, but haven’t done wall mounts before, and need advice on installing them.
From what I have been able to find for instructions. I gather that I install the backer nuts, so that the bottom two are true to the wall, and the one on either of the uppers is plumb to the bottom. Then, I install the ring and toilet, and tighten the three nuts with backers on until they are finger tight, plus a 1/2 turn, and then run the fourth nut on finger tight.
Am I understanding this correctly?
Greetings J,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
can another bump help???Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Sometimes.
Is there a plumber in the house?
Looks like it's a no show here at Breaktime regarding your question.
If you were to Google 'plumbing forum toilets' you will receive a number of various forum links that are more specifically geared toward the info you request.
Cheers.
Edited 8/11/2007 12:34 pm ET by rez
Try Terry Love forums
Installed a wall mount about 6 weeks ago, the instruction that came with it were very similiar to the description you gave.
I believe they said tighten the bottom two first, I kinda went by the way they felt to me.
Then tighten the upper nut that has a backer nut behind it .
The fourth nut was to be run up until just snug.
Wax seals are a no no on wallmounts use the foam kind , some come with an adhessive.
Someone to help hold it in place while you tighten is very helpful.
