Wall mount used as Ceiling light fixture
frederic | Posted in Energy, Heating & Insulation on November 10, 2003 07:46am
I just bought a wall mount light fixture which a label inside states that it is for wall mount purpose only but I had the intension to use it as a ceiling fixture.  I contacted the company and the tech. was not sure why this is except that it was only tested by UL for that purpose.  Is there any reason why I couldn’t/shouldn’t use it on the ceiling?
Freddy
    ProDek | Nov 10, 2003 08:06pm | #1
    You might not like looking at the exposed light bulb at one end of a wall sconce.
    I believe the mounting flange on a ceiling mount is insulated to dampen the heat from the bulb, but you better get some advise from an electrician
    Bob
    1. frederic | Nov 10, 2003 08:25pm | #2
      Now that you mention it they did say something about heat on the ceiling but did not elaborate.  I apprecite the info. and will get a proper ceiling mount.
      Thanks again.
  2. DavidThomas | Nov 10, 2003 09:58pm | #3
    Heat dissipation from a vertical surface (wall mount) is much diffirent and much better than heat dissipation from a horizontal surface above (ceiling mount).  The manufacturer/UL may only have tested it on a vertical surface, it may have passed by a wide margin and MIGHT be okay on a ceiling.  But sight-unseen, shoot-from-the-hip, SWAG by someone who listened pretty carefully during those upper-division course on heat transfer (me): If the wall-mount is rated for 100-watts, that would equate to maybe 40 watts in a ceiling-mount.  If the wall-mount is 60-watts then a similar reduction doesn't leave much wattage for the actual illumination task at hand.
    David Thomas   Overlooking Cook Inlet in Kenai, Alaska
