Wallpaper in Bathroom?
user-7194725 | Posted in General Discussion on October 27, 2021 07:30am
Hi All,
I’m planning to wallpaper my guest bathroom, and I’m trying to decide if it’s a bad idea to continue the wallpaper above the tub surround. It’s an interior room, but I have installed a new, more powerful fan. I’ve heard both things – that it will peel in no time and that it will be fine. The problem is that I’ve been unable to match the existing shower tile, so if I were to extend the tub surround to the ceiling, it would be obvious where the new tile was added. Thanks in advance!
  1. bing0328 | Oct 27, 2021 06:15pm | #1
    Couple of questions. Is the new fan a Panasonic squire cage type or a Fantech inline type?
    Is the fan wired to go on when the light goes on or is it separate switch? And this is a guest bathroom so it's not going to get used (shower) everyday?
    1. user-7194725 | Oct 29, 2021 08:32am | #3
      It’s a square-cage type Panasonic fan that’s on a separate switch. It’s a guest bathroom but also the bathroom for my two kids (preteen girl and toddler boy). I’m primarily concerned because of my daughter’s love of long showers.
      1. bing0328 | Oct 31, 2021 05:41pm | #5
        Given it's going to be used virtually everyday, I'd recommend painting and using stencils or other decorative painting and not and i repeat not wallpaper. It will peal.
        (Andy your back splash is like a desert compared to the humidity in that bathroom).
        Put the fan switch on a timer so that it stays on at least 20 minutes after your daughter finishes in the bathroom. Nomorecoffee's idea is a good one and I recommend it because paint above shower tile is the first area to show signs of
        distress.
  2. andy_engel | Oct 27, 2021 06:53pm | #2
    We used a wallpaper frieze for a kitchen backsplash, coating it with dead-flat varnish. It's held up for years.
  3. nomorecoffee | Oct 29, 2021 11:23am | #4
    You don't have to match the existing tile. Could do a stripe along the top of the original layout and add a checkerboard pattern above that with different colors or something so it looks intentional.
  4. fsmyles | Nov 01, 2021 09:24pm | #6
    Depends on the wallpaper you use. Most porous wallpapers will fail in a bathroom over time. Vinyl papers will not. Don't go cheap on the glue or the wall primer (RX-35).
    Frankie
    1. bing0328 | Nov 30, 2021 12:07pm | #9
      I have seen vinyl wallpapers fail and they are a great mold collector to boot.
  5. lisahaley | Nov 06, 2021 03:23am | #7
    I was also facing same problem.Thanks for guidence.I will use good quality primer due to porous wallpaper.
    user-6583732 | Nov 29, 2021 05:35pm | #8
    2nd stencil or a decorative paint border.
    Wall paper is awful to re-visit. Even to just refresh
    the room in a few years.
    Stop the hot water - mixers have a limit. Here the code is sort of
    low - until you consider all of the steam said teen would generate
    if the water were hotter - than code.
    A crown molding would be nice ...
Choosing a Paintbrush
  • The New Old Colonial
