I’m looking for a plumber in New Orleans, LA to do some work ASAP. If anyone has names numbers etc. I would appreciate it greatly.
I’m in the middle of rebuilding my flooded home at the moment, and I need some plumbing work.
Specific work to be done.
1. I have a cast iron waste line that is serviceable, but corroded and will be buried in a wall, It needs to be replaced before moving forward.
2. I need to tie in a shower and waste line from a sink into a cast iron waste line and run hot/cold service too these two same locations. This will require cutting into the slab at this location.
3. Replace service and drain lines to laundry area.
Right now the whole area is down to the studs and open. Power/water/gas is there and the whole area is clean and safe to work in. I can prep the whole area and do the slab cuts any prep work you want. I’m the homeowner/novice GC running the project and fully admit I’m a greenhorn. I would love to have someone come by ASAP to consult and schedule for the work to commence within the next two weeks.
I had a local plumber lined up to do this work. They told me that because of demand for basic service connections they were no longer going to do “remodel” work only water/gas restoration. Honestly, I can’t argue with that but this has blown my scheduling.
Timing for me is critical, as the plumbing work falls on my projects critical path. I’m doing a concrete overlay of my whole slab and acid staining that. I can’t do internal framing before that is done, and I need to have the plumbing and any slab cuts that may be required done before I do the overlay.
