Washing Machine Pan
michael2160 | Posted in Construction Techniques on January 2, 2012 05:48am
I am moving a laundry area from my garage to an second floor location and wil have a local sheetmetal mechnic bend a drain pan
I need advice on what galvanized sheet metal thickness the drain pan should be: 20ga, or something thicker.  I am going to lay the pan over a layer of neoprene sound insulation so the pan needs to be strong enough that the machine pads don’t dent the GSM.
I have not found a commercially made drain that meets my needs.
  1. Piffin | Jan 02, 2012 05:54pm | #1
    20-24 should be plenty trhick
    1. michael2160 | Jan 02, 2012 09:33pm | #2
      Thanks Piffin
      If the $ delta isn't too much I'll go with the 20 ga.
  2. davidmeiland | Jan 03, 2012 12:48am | #3
    20
    probably almost no cost difference.
    You going to run a drain line through the floor to the outside? Through the side of the pan? Just curious...
  3. jetfueltypea | Jan 03, 2012 09:53am | #4
    washing machine drain pan
    Camco 20752 30" $21.67 or Oatey scs 34051 $24.99
    Made for this application
    cheaper than Galvanize sheet metal and has the male adapter to run to an external drain if there is a leak
