Water based polyurethane recommendations
![](https://secure.gravatar.com/avatar/1148f1d5fe407d125139109de01bdd02?s=52&d=https%3A%2F%2Fimages.finehomebuilding.com%2Fapp%2Favatars%2F200x200%2Fa.png&r=g)
I need to finish the interiors of several wood windows and want to use a water based polyurethane. It’s very cold here so really don’t want to leave the windows open for ventilation after using a high VOC product. Does anyone have any recommendations on particular products they’ve used? Thanks.
If you are spraying I like the enduro coat. I havent tried it using a brush. Another one is the Flecto varathane. its pretty good . But If your in a area where it cold be sure to stick the can of finish inna hot pan of water to warm it up or it wont flow right.
Darkworksite4:
Estamos ganando detrás el estado de Calif. Derrotando a un #### a la vez. DESEA VIVO LA REVOLUCIÓN
