I have a small area in my bedroom closet, where
the airconditioner leaked water and damaged the
ceiling and side wall. The area is about 3X5.
I am pretty handy, so I could cut it out and
redo the drywall. But since it has dryed it
don’t look too bad. It does have a smell of mildew (I guess), Can I just dry it very good
clean with clorox, and repaint it.???
Thanks in advance
This centuries-old paint offers vapor-permeabiity, maintainability, and longevity with zero VOCs, but know its limitations before you get to work.
Ray 'you might as well try it , lot's easier than ripping it out .I dont know about the mold or mildew inside the wall , I think it requires moisture to survive ,[ I'm sure someone will correct me if I'm wrong ].So if you have the leak fixed and its dried out you may be ok . If not you can always tear it out later ' Good luck , Chuck
*I agree with Chuck, it's worth a try. Wash it with a solution of TSP (trisodium phosphate) and bleach using a damp sponge. Aim a fan into the closet to help it dry. Prime with BIN or Kilz to seal the water stains. It may take more than one coat if the stains are severe.
don't look too bad. It does have a smell of mildew (I guess), Can I just dry it very good
Thanks in advance
