Water damaged drywall ceiling
mbr440 | Posted in Business on November 4, 2005 06:03am
Newbie hear, longtime reader of FH. I need help with a damaged drywall ceiling. Water from above caused the drywall to swell abit. Screw dimples and seams are now visible. I have cut some small holes and verified all is dry with no stains. Now do I remove all upper cabinets from the kitchen that was installed a year ago and re& re..or can I sand mud and paint.? Thanks in advance..
    Huck | Nov 04, 2005 10:34am | #1
    if there is no mildew, and no buckling, I would just re-tape, finish and texture to match, and paint.
  2. Mooney | Nov 04, 2005 12:01pm | #2
    Your answer is yes.
    Welcome to Breaktime.
    Next time post this type of thread under construction , unless you want to talk about making a living fixing ceilings. <G>
    Tim
    1. mbr440 | Nov 04, 2005 06:10pm | #3
      Thanks, and my bad I am just learning the ropes to this format.
      The strength of the drywall has not been comprimised? Should I re screw?
      My plumber is eating this one, so he will be happy with the second opinion.
      Thanks again.
      1. pickings | Nov 04, 2005 06:29pm | #4
        "Should I re screw? "
        DW so NO...... ;-)...but, since you are going to "skim coat" anyway, push on the ceil @ the frmg members. If you have any movement, it will not hurt to drive a couple of screws in there.
        Easier now than after it's repainted.
      2. DanH | Nov 04, 2005 08:29pm | #5
        If the drywall has swollen at all, it's strength HAS been compromised, but not enough to worry about. So long as there's no sagging and it can be refinished to a suitable finish there's no NEED to replace it.But sometimes it's easier to replace than to deal with the finish imperfections that may be present, and if there's even a small part of it that needs to be torn out then you might as well tear out the bulk of it -- not much difference in effort redoing a 4x4 inch piece vs a 4x4 foot piece.
        No electrons were harmed in the making of this post.
        1. mbr440 | Nov 05, 2005 03:46am | #6
          Thanks for the info everyone, The drywall feels solid and I would most likely replace it all if the upper cabnets did not go right to the ceiling.
Two Ways to Test Windows
  • The New Old Colonial
