water drainage between slab and wall
fivestar | Posted in Construction Techniques on May 26, 2003 09:35am
I’m looking for a plastic drainage system to put between the soon-to-be-poured concrete slab in a basement and the basement concrete wall. The system is designed to channel water seeping through the wall under the slab where it can be picked up by a sump. I have seen an article/ ad about this but now I cannot find any info.
  1. Ethos | May 27, 2003 04:13am | #1
    NDS makes channel drain.  Home Depot carries some, but check with a plumbing supply house for NDS's catalog, etc.
    1. fivestar | May 29, 2003 06:59pm | #4
      thank you for replying.
  2. ahneedhelp | May 27, 2003 05:34am | #2
    May I ask if this is a setup for in case there is a problem or are you anticipating this to be a regularily used/functioning system for water infiltration that is expected to seep through the walls ?
    Or maybe this is an alternative to a floor drain ?
    I hope you don't mind me asking.
    Just curious.
    1. fivestar | May 29, 2003 06:56pm | #3
      this is a just in case item. I want to be able to deal with any water by putting it under the slab and into a sump.
      thanks for replying
      1. ahneedhelp | May 29, 2003 08:47pm | #5
        re - this is a just in case item.
        Thanks for answering.
        Nice to plan ahead.
