Hello everyone
I have purchased a water heater from HD, and I have noticed that the water tank is already insulated with a layer of fiber glass.I am wondering if I should use a extra blanket for insulation.
Thanks for any input!
P.S:Can anyone explain me what is BTU stands for?
Yes, you should add more insulation, but only if you want to save the added money.
BTU = British Thermal Unit. It's a method of measuring the amount of heat that is created by a device. By comparing BTU's produced to energy usage, you can get an idea of relative energy efficiency among various brands.
Unless you're the lead dog, the view just never changes.
thank you very much!
I'm so cheap I built a box around the WH with R19 around it.
A BTU (British Thermal Unit) is the term for the amount of heat needed to raise the temp of water 1 deg F, from about 39 F to 40 F (I'm not precise here).
1 kW-hr = 3413 (or 3412 depending on specs/rounding) BTUs.
Thank you very much!
Is this a gas fired water heater? If so, be VERY careful about adding extra insulation so you DO NOT:A - have the insulation blanket near the flue pipe
B - cover any of the openings that allow combustion air in to the burner.BTW, a BTU (British Thermal Unit) is the amount of energy required to raise the temperature of one pound of water, one degree fahrenheit.
Edited 11/2/2005 10:22 am by allaround
