Water Heater with hot and cold switched
ramertt | Posted in Energy, Heating & Insulation on January 27, 2009 02:04am
This one is for the plumbers out there.  I recently remodeled a fixer upper and noticed the incoming cold for the water heater was piped into the hot on the water heater.  The hot water comes out the cold pipe.  This is the second house I have seen this mistake on.  My question is ..is it ok to leave it or should I switch it back correctly.  What could happen if its not piped correctly?
    Sphere | Jan 27, 2009 02:11am | #1
    Can't be as effiecient with the dip tube drawing from the bottom I'd think.
  2. DanH | Jan 27, 2009 02:12am | #2
    It may actually be correct -- if the plumber swapped the dip tube. Sometimes the heaters are installed "backwards" because the pipes work out better. The difference between the two ports is that the cold port has the dip tube in it.
    If it's backwards you'll get complaints about having very little hot water.
    1. ramertt | Jan 27, 2009 02:14am | #3
      The hot water is fine.
      1. DanH | Jan 27, 2009 02:18am | #4
        Then I'd leave it alone.
  • A Postwar Comeback
  • Natural Simplicity
