water in conduit
Houghton123 | Posted in Construction Techniques on September 30, 2010 12:02pm
Weekend (well-FT, I’m retired) worrier here.
I’m pulling wire to an outbuilding through PVC conduit installed over ten years ago and recently extended to the building.  I just duct-taped the buried end of the conduit when my son ran it under the sidewalk behind the house, and it’s got water in it.
It won’t be a hard pull – four #8 wires in 1″ conduit over a 32 foot run – but should I run a rag through the conduit a few times to clear the water and dirt?
Bill
  1. gfretwell | Sep 30, 2010 02:10pm | #1
    Water in underground conduit is expected. You can suck the excess water out with a shop vac while you are sucking a pull string through If you think there is dirt in there I would pull a rag through to get as much out as I could.  Then suck some lube like "Yellow 77" through and stuff in the wire.
    1. Scott | Sep 30, 2010 02:31pm | #2
      I've wondered about this.... considering that water will eventually be in there due to condensation, should you use something like NMWU or can you get away with regular NMD?
