Water line for ice maker
Stan | Posted in General Discussion on June 23, 2008 02:04am
Two years ago we went through a major kitchen / linving area remodel.  When the the water line for the refridgerator ice maker was plumbed in the plumber used a plastic water line that came off of our under the sink mount Multi-pure water filter.  Towards the end of the remodel, the line started leaking and the general contractor called the plumber back and he fixed the problem.
Then last August / September (a year after the remodel) the water line leaked again.  This time I fixed it.  The water line held until two weeks ago when it developed a pin hole size water leak  just on the supply side of the compression fitting.  I repaired it .  Then again today the supply water line sprouted another pin hole water leak one to two inches up from the compression fitting.
I am gathering that plastic supply hoses are vulnerable to pin hole leaks.  Does anyone know if there there are plastic lines that have a higher PSI rating than others?  If so, can anyone give me any insight or share thier knowledge base.  Or should I yank the plastic out and replace it with copper – even with the line be connected to my non- reverse osmosis Multi-pure water filter?
Thanks ahead of time for the great answers that I know that I will receive. (This might be a great article for FH magazine…whatcha think???)
Stan
  1. BigBill | Jun 23, 2008 02:27am | #1
    I personally have had problems with plastic lines becoming brittle and leaking.  I now use copper for ice maker lines and put a valve at the end and use a stainless braid covered Teflon line for the flex connection to the fridge.
    1. Stan | Jun 23, 2008 04:31am | #2
      Thanks BigBill for your reply.
      Since posting my question I have done some research.  What about replacing the existing plastic tubing with 1/4" PEX?
      Stan
        BillHartmann | Jun 23, 2008 05:36am | #4
        When I bought a new refigerator a couple of years ago I asked about delivery and most stores told me that they will not hook up a water connection with plastic tubing. Had too many leak and then the HO tried to blame the store's installers.I recently stripped some wallpaper on a kitchen and had to move the refigerator. The lable on the back said to use Copper or a GE PEX kit. It had 1/4" PEX on it. I had never seen that before, but should be good..
  2. peteshlagor | Jun 23, 2008 05:23am | #3
    Your appliance store will have one in stainless steel braiding.
    1. Stan | Jun 23, 2008 05:21pm | #9
      Great suggestion, but I am 16' from the water filter.
    2. Stan | Jun 24, 2008 08:27am | #11
      After going to Home Depot, a lumber and building supply store and then finally to another hardware store, I was able to find a 20' length of 1/4" Stainless braided water connector line.  As much as I really wanted PEX tubing, this I believe will be a better choice than using copper, which I found out leaves a metal taste in the water.
      I want to thank EVERYONE who contributed to helping me out!!!
      Thanks so much.  Now I just need to find out how to go about contributing a story to FH.
      Stan
    Ted W. | Jun 23, 2008 10:24am | #5
    This might be a great article for FH magazine...whatcha think???
    I agree, you should take some photos of each type of installation for the article, write it and send it in. I understand if they publish it they'll pay you for it.
    I like the one suggestion of using stainless braided flex at the end. I'v often had the problem that when I move a fridge the slight movement of the copper tubing tends to loosen it a little and cause a leak.
    PEX would be a good solution, as would copper. Plastic should be outlawed.
    Cheap Tools at MyToolbox.net
    See some of my work at TedsCarpentry.com
    1. wane | Jun 23, 2008 03:10pm | #6
      Never seen braided 1/4 lines for an icemaker, sink & toilet yes, icemaker no, besides the issue isn't high pressure it's bad plastic/aging.  Copper is the propper route, almost every manual I've checked says copper, not plastic ..
      1. BigBill | Jun 23, 2008 04:25pm | #7
        The big box stores carry them.
      2. JTC1 | Jun 24, 2008 03:15pm | #12
        Fluidmaster makes a 10' x 1/4" braided line specifically labeled for icemakers.
        Fittings thread directly to 1/4" compression fittings.
        10 year warranty.
        JimNever underestimate the value of a sharp pencil or good light.
  4. VAVince | Jun 23, 2008 04:38pm | #8
    I ran into the same problem that you are having.
    I ran 1/2" PEX and mounted a shut off behind the frig. Used a braided line from there to the icemaker water valve.
  5. roger g | Jun 23, 2008 07:58pm | #10
    When I was the Maytag man I installed many lines to the ice maker. It was always 1/4inch copper and was curled around in a circle at the back of the fridge so you could easily pull the fridge out from the wall.
    roger
Picture-Perfect Pergola
