After recently purchasing a new residence I have learned that the pitch of a concrete patio on the high end of a structure is pitched toward the structure. Water builds against the two sliding doors and penetrate after a rain. Friends have mentioned the potential of a curtain drain and this sound good but I do not really know what one is. Any help would be appreciated.
Construct the intersecting gable on the main roof for a faster, easier-to-build assembly.
How big is the slab? Is it pitched toward the house because the backfill settled? Or because the yard generally grades that way? It sounds like cutting in a 6" or 8" trench drain is what you want to do. A curtain drain means a trench and a backhoe right next to your house, quite invasive and doesn't fit your description. More info needed.
-Rob
*I would think that you would have longer lived, more permanent, and lower maintenance solution to replace slab with one pitched away from house. Slab jacking or a new topping if there's enough elevation may be less expensive route to same ends.
Sound like the soil under the slab next to the house was not compacted when backfilled. Differential settlement caused slab to drain to house. A curtaindrain is typically used to drain groundwater. It is a trench excavated to an elevation lower than the thing you want to protect. The trench is filled with crushed stone or washed gravel with a perforated pipe at the bottom. The pipe is outletted somewhere down hill or into a basin with a pump. This drain is not appropriate for your situation. The trench drain will work but requires maintenance on your part. I like replacing the slab.
