I found the BACK side of one of my siding boards to be wet. It was a horizontal 1×8 cedar piece and the one above it was not wet.
The piece is on the side of a large dormer, and was near the roof (that is, it was a short 4 foot piece with one end butted up to the dormer corner board, and the other end is cut at an angle and comes within 1 inch of the roof shingles.
Most siding on my house is away from the “splash” effect of rain. Usually by being 2 feet above the ground. But these dormer side pieces , where they intersect the roof seem to me to be in the splash zone of rain hitting the roof and splashing up from the bottom side onto the horizontal siding joint.
What stops the splash problem here?/
Should these horizontal joints be caulked?
nailed together tighter?
bump
Looks like '02 was a slow year for getting any answers.See my work at TedsCarpentry.comBuy Cheap Tools! BuildersTools.net
If you haven't already done so, please update your profile. Since many issues are dependant on the region in which you work, we often look at your profile to see where you are writing from.
What you talkin about Willis?????
geeez rez... gimme a break.... whatta u doin ?Mike Hussein Smith Rhode Island : Design / Build / Repair / Restore
you don't say where you live
if the boards are 1" above the roofing material , AND they were end primed and back primed ... then they should stay dry
if you are in a very wet climate, you might have to do something a little more defensive
