Water-stained drywall-replace or paint?
| Posted in General Discussion on August 30, 1999 03:00am
A good coat of kilz should cover up any water stains. If the drywall is’nt damaged, don’t do more work than neccasary.
  1. Guest_ | Aug 30, 1999 03:00am | #4
    Need some advice from re-habbers or drywaller types. My sister-in-law is looking to buy a condo in Chicago which is being re-habed. Part of the re-hab involves fixing a hole in the ceiling drywall caused by a roof leak (also repaired). Around the hole there are water stains which range up to 10 feet away. The builder says that only the hole needs to be patched and that the stains, which do not appear to be "textured" differently than the undamaged drywall, will simply be repainted.
    Does this make sense? Or should all water-stained drywall be replaced?
    1. Guest_ | Aug 23, 1999 07:38pm | #1
      *If the drywall is still sound, the water stains shouldn't be a problem, provided they are sealed with a primer/sealer such as B.I.N or Kilz. I think the real concern should be the insulation above the ceiling. Is it still wet or was it damaged by the water?
      1. Guest_ | Aug 24, 1999 12:55am | #2
        *On BIN/Kilz, which I've been using lately, is there reason to use anything else to prime? They are inexpensive, dry quickly (1 hour to recoat!), seem to work well, and have the extra benefit of sealing knots, stains, odors, redwood, etc.
        1. Guest_ | Aug 24, 1999 10:25pm | #3
          *I've had problems where if the whole wall wasn't primed, the spot prime would telegraph through the top coat. Sometimes too, where changing color, I'll use a good latex primer tinted to match the topcoat ......I'm not sure if BIN can be tinted.
          1. Aaron_Miller | Aug 30, 1999 03:00am | #5
            *A good coat of kilz should cover up any water stains. If the drywall is'nt damaged, don't do more work than neccasary.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
