Is it necessary to have a lower wall water table and drip cap or is it acceptable to just start my new f/c siding where the wall meets the foundation?
thanks
Not necessary.
That is a style issue not a requirement.
usually a matter of taste and style.
Do you like miniskirts or hoop dresses?
Cowboy boots or clogs?
thanks guys,
Just be careful the FC doesn't start too close to grade. Handi recommends their siding start no closer than 6 inches to finished grade. I assume that's to minimize backsplash.
Handi install link: http://www.jameshardie.com/pdf/install/install_plank_north.pdf
Edit, added link
Edited 8/31/2008 12:46 pm ET by NickNukeEm
Like the guy said it's a style thing. With fiber cement you don't have to worry about the first coarse of material wicking up moisture (from snow etc) if your siding has to be close to the ground or an intersection of (roof). In my home alot of the board and batten siding is just off the surface below and recently I've had to cut out rot and retro fit with an AZEK skirt board.
Glad to know someone besides myself calls the bottom piece a skirt board.
I'm a big fan of correct terminology and I find, at times, some things can have more than 1 correct name . Looking up they are rafters, standing on them they are joists. Always learning.
Speaking of terminology, I'm not sure I followed you on the >> Looking up they are rafters, standing on them they are joists <<
What he is saying is, if he just fell into the basement through the floor joists and is now looking up at them, they are now rafters.
Not what I call rafters - but that's just me...
I was just joking around. He was saying something I have heard before, tho, about joists are things you can stand on while looking up at rafters.
Something you might say to someone who had no knowledge whatsoever about the names of the parts of a building.
You're joking, right?
Joe Carola
Small joke.
Very small, apparently.
