Water well pump problem
objector1 | Posted in General Discussion on September 18, 2008 03:24am
 I am in the process of converting an old jet pump well system to a submersible pump system. For sake of economy, and because it was there, I am using a 12 year old 1/2 horse pump. The pump was installed in my father’s well and was pulled after just about an hour because the well was muddy. It has just set around and I decided to use it when my jet pump started to cause problems. Last year I started it in a barrel of water and it pumped strong for several minutes.
 Today I installed the pump and when I started it , it would run for about 5 seconds and stop. I can turn the power off and right back on and it runs, but only for five seconds. I have been testing it by putting it in the well and running the power directly from the disconnect to the pump power line. Initially I hooked up the entire system, running it through the pressure tank (etc) and it did not work then but just for a few seconds.
 Any and all advice would be greatly appreciated!
  1. McPlumb | Sep 18, 2008 03:57am | #1
    Check the amp draw, 110 should draw 11 +/- 1 amp.  220 should draw between 5 and 6 amps.
    You could try raising the pitless to the top of the well casing and block it there, then kick the power on and see what it does.
    BillHartmann | Sep 18, 2008 04:16am | #2
    As stange at is might be centrifical pumps draw more current when they run with an open discharge than when they are pumping into a dead head.
    And some submersiable pumps are made for use in deep wells. That that means that that might have over 100 psi head before you get a drop of water.
    so running it with an open discharge is much different than it is designed for and thus the motor can over load.
    However, I would expect that it would run a little longer than that before the internal overload protect would shut it off.
    But get the brand and model number and then get the manual.
  3. inperfectionist | Sep 18, 2008 05:17am | #3
    Almost seems like a piece of junk stuck in the pump,,, unlikely though.
    Really need to see what she's pulling for current when she's pumping , and when she stops pumping.
    Those motors do not like sitting around for twelve years drying out( their full of liquid).
    Get those current readings, also, meg the motor.
    Harry
