I was refinishing some 115 year old 3 1/4″ fir flooring, doing my first ever attempt at applying a finish.
After doing about a 1000 sgft with a fiber bristle finish applicator, trying not to trap myself in a corner, I discovered, returning a few hours later, I created a couple of puddles next to a wall.
I’m using Bona waterborne “Traffic” finish. I snowplowed the finish like the directions indicated, but had some passes that were close to 20′. By the time I got about 10′, I’d run out of finish. Starting mid pass would cause a concentration of finish, so I poured too much when I got to the last pass and unknowingly left a puddle about 8” from the wall.
Upon my return about 2 hours later, I tried to scape the semi hardened puddle flush, but left a white edge around the outside of the puddle.
Anyway to blend this in to the 2nd coat with sanding or screening? Thanks for any tips or advice
Greetings fossil,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
94969.19
In the beginning there was Breaktime...
94969.1 Photo Gallery Table of Contents
The white stuff is no problem at all. As long as the area is relatively flat, the second coat gets rid of all the white stuff - that is the beauty of these kinds of finishes. If you mess up, you just sand and re-coat. Think of it as drywall mudding, not concrete work: you get as many second chances as you want.
I have also found with Bona and similar water based finished that the odd puddle or drip becomes much less conspicuous over time. I don't know if it shrinks as it continues drying or what, but in a month or so it is hard to find where they were.
Touch ups when a small area is damaged are easy too. New coats blends with the old very well.
