waterproof basement for new construction
malibuds3 | Posted in Construction Techniques on July 15, 2008 04:47am
My block walls are going up for the basement (could not afford Poured or ICF). heres the plan… Rub-R wall spray on with dimple mat glued on to it and J-drain foundation drain. Any other suggestions? I thought about putting a foot or so of gravel over the J-drain. does perforated pipe work any better? thanks for any suggestions I just don’t want any moisture problems.
  1. wane | Jul 15, 2008 03:46pm | #1
    j-drain ?
    1. malibuds3 | Jul 15, 2008 03:54pm | #2
      it is a rectangle drain that wraps around between the footer and against the wall comes w/ a sock and does not require gravel
        BillHartmann | Jul 15, 2008 06:14pm | #3
        Without going through their whole website it appears that J-drain is just for interior use.But there might well be some for exterior.Is it similar to form-a-drain?http://www.certainteed.com/CertainTeed/Pro/Contractor/Foundations/.
        1. DaveRicheson | Jul 15, 2008 06:24pm | #4
          http://www.j-drain.com/sub-app-basement.php
          Doesn't look like Form-A-Drain.
      2. wane | Jul 15, 2008 06:40pm | #5
        that's what I thought, so he still needs big-oh with a sock on it around the perimeter of, and just below, the footing ..
        1. malibuds3 | Jul 16, 2008 01:16am | #6
          This passes code as a foundation drain you put up against the wall and backfill no perforated pipe or gravel
Grout-Free Shower Panels
