waterproof slap
traini | Posted in General Discussion on August 28, 2008 02:48am
 A client has a room under the front  concrete stairs and entrance to the house, this 8’x8′ cold room has water/moisture entering via the concrete roof. The concrete is covered with a 1″   irregular flag stone that will be removed. ANy proven methods to waterproof with some type of membrane, then  install a natural stone or concrete finish.
George
  1. rlrefalo | Aug 28, 2008 03:54am | #1
    Go to sanitred.com. I've used their products for lining a masonry fountain. Worked well. It is suitable for your use also.
    Rich
  2. RedfordHenry | Aug 28, 2008 05:18am | #2
    Shower pan liner?
  3. MikeHennessy | Aug 28, 2008 02:40pm | #3
    Ditra under the new stone?
    Mike Hennessy
    Pittsburgh, PA
    1. traini | Aug 29, 2008 02:36am | #5
      Thank you
      I thought of Ditra  or Kerdi, I would think that Kerdi as a shower pan liner should work, Exterior?? frost?? If I put Kerdi down first with Thinset, Then Ditra over top with Thinset, Woud I be able to optain both water proof and crack residents??
      George
      1. MikeHennessy | Aug 29, 2008 02:21pm | #7
        Ditra will be waterproof, except for at the seams, and a better isolation membrane. You could maby use Kerdi strips just under the seams with at least 2" overlap. A call to Schluter may be worth the dime.
        Mike HennessyPittsburgh, PA
  4. Muttly | Aug 28, 2008 02:52pm | #4
    Are you in a freeze/thaw area? that would affect any applied waterproofing and the finish on top of it.
    1. traini | Aug 29, 2008 02:37am | #6
      It is in a Frost zone, Toronto, Ont.,
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
