Waterproofing a concrete roof deck
AXE | Posted in Construction Techniques on January 25, 2004 11:19am
This last week I poured a structural concrete deck.  It is over living space in the basement so needs to be waterproofed.  It will eventually be a covered screen porch so it won’t see much water, but will get some when it really blows around.  After waterproofing, I will be pouring a topping slab or laying flagstone over the whole thing.  So it doesn’t seem like a highly critical application, but I also don’t want to be tearing up my porch a few years down the line.
A local roofing guy is suggesting a product called Ruberoid.  He says it is about 1/2 the cost of EPDM and since UV rays is what kills roofing, he anticipates many, many years of good service in a covered application.
I’m pretty well sold on the idea but thought I would check in here to for input before going ahead.
Thanks MERC
  1. Piffin | Jan 26, 2004 04:53am | #1
    Normally, a ply of waterproofing would go down before the concrete but since you are at this point and still have a tile job going down, maybe you can get by with some peel and stick material like ice and water. Maybe this Rubberoid brand name is such a one.
    Polyglass is another that is made for low slope roofing and has granules that could help with traffic in the meantime
  2. roofdoc | Jan 26, 2004 08:24pm | #2
    ruberoid is Gaf's (read manufactor)name for torch down which is applied with a open flame it has been my experance that most times the field application is alright but when it comes to details such as tieing into or flashing walls of a wood structure the use of open flame does not allow for proper installation
    EDPM may agood installation but I would suggest the use of a reinforced membrane, or you might ask for a TPO product which is a marriage of EDPM and theromplastics that is seamed and detailed with hot air.
Fast, Accurate Wall Framing
