Waterproofing a Deck
GaryW | Posted in General Discussion on December 11, 2006 07:00am
What is the material or coating used to waterproof a deck? I’ve heard of, but google doesn’t turn up info on products called “Vicor” and “Pebble Tech.”
This is for a Honolulu, second floor deck, with provides access to two apartments. We’re trying to protect the first floor apartments below from current (no pun intended) water damage. Presently the deck is of T&G 2×6 D.Fir, which we intend to remove & replace with two layers of plywood and waterproofing – either with or without a membrane. We must take up the deck to increase the pitch away from the building, and possibly gutter the runoff away from the first floor patio below.
Gary W
gwwoodworking.com
    DDay | Dec 11, 2006 08:26pm | #1
    You were probably looking for Vycor in your search, that is a membrane made by W R Grace. The vycor would not be what you want for your project, others will chime in that know far more abou this topic than I do but they'll probably suggest EPMD. Do a search through the archives of posts here, this topic comes up every once in a while.
    1. GaryW | Dec 11, 2006 08:40pm | #2
      Could what you're referring to be EPDM? - http://www.epdmcoatings.com/. That looks more like a roofing product. I don't see anything on the web site about using it for a deck - to be walked on.Gary W
      gwwoodworking.com
      1. NCtim | Dec 11, 2006 09:28pm | #3
        I was looking at an old FHB from 2004 this morning and there was an advertisement for a decking product you'll be interested in. I'll post the name of the company after I get home tonight.NCtim
        1. GaryW | Dec 11, 2006 09:51pm | #4
          Thanks, I'll look forward to seeing it.Gary W
          gwwoodworking.com
          1. NCtim | Dec 11, 2006 11:51pm | #5
            Hey Gary,
            It's in issue number 162 as well as others. Global Decking Systems.
            http://www.globaldecking.com
            It says it supports exactly what you're trying to accomplish. Good luck.
    2. Piffin | Dec 12, 2006 03:59am | #7
      EPDM
  2. JoeArchitect | Dec 12, 2006 12:09am | #6
    Check out http://www.dexotex.com. I've used this a number of times in the midwest where I had a second floor deck above a first floor living space. It's non slip, trowel on elastomeric membrane, expands and contracts with temp fluctuations, can be applied on plywood,and comes in many colors.
    1. GaryW | Dec 12, 2006 07:01am | #8
      Dexotex looks pretty good.
      Anyone else with experience with their
      Elastatex 500 Elastomeric Waterproofing?Gary W
      gwwoodworking.com
  3. peteshlagor | Dec 12, 2006 08:30am | #9
    http://forums.taunton.com/tp-breaktime/messages?msg=82474.8
  4. mcadioli | Dec 12, 2006 08:56am | #10
    we use this http://www.spec-net.com.au/press/0405/davco.htm  product for our wet areas. It is also suitable for exterior )(UV proof) and is trafficable. Water clean paint on.
    regards
    mark
  5. dovetail97128 | Dec 12, 2006 09:14am | #11
    I used this in the past for what you are doing
    http://www.gacoretail.com/gacodeck.html
    1. GaryW | Dec 12, 2006 08:12pm | #12
      Thanks all for your help,
      Including some already mentioned here, I've located a number of coating systems to waterproof a deck. Among them are http://www.dexotex.com/index.php?href=productdetail&id=29, http://www.gacoretail.com/gacodeck.html, http://www.epdmcoatings.com/, http://www.miracote.com/index.php?href=products&query=1023. I'd like to use a complete system from primer coats to a colored top-coat and wall flashing. I'd rather not use, and don't think we need a system with a complete membrane.
      Thanks again, I've learned a lot here and at the JLC forum.Gary W
      gwwoodworking.com
      1. coatman | Dec 13, 2006 01:48am | #13
          http://www.grailcoat.com may be something you may want to check out. A good slope away from the building is a great idea, also flashing and drip edge.
  6. mike4244 | Dec 13, 2006 02:23am | #14
    EPDM, I believe is what you are lookung for. Available in liquid form also.You mix a catalyst with the base coating and pour it on the deck.A large squeegee moves the stuff around. Not exactly self leveling but easy to get a uniform thickness. 1/8" thick should do the job. You need some type of edge form ,even a high bead of caulk will work.
    I believe it comes in black or white.I paid $75.00 for a gallon about 5 years ago.About 40 sf of deck,was done in a half hour. You can apply this in any weather,will not dry til the air temperasture reaches a certain degree ( do not recall).It still will be waterproof even if it stays wet for months.
    I did this small widows walk in december ,dried to the touch in april.In the meantime the room below was dry as a bone.
    mike
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
