In a couple of different videos I’ve seen a recommendation for a waterproofing solution to put on the ends of posts that are going in post bases. But I can’t remember what it was, and can’t find the videos. Can anyone help me out?
Thanks.
Thanks.
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
Please refer to the following code Sections, that should help you with your project:
https://up.codes/viewer/ohio/ibc-2015/chapter/18/soils-and-foundations#1807.3
https://up.codes/viewer/ohio/ibc-2015/chapter/18/soils-and-foundations#1810.3.2.4
Thanks for the guidance.
