waterproofing round shower window ?
ANDYSZ2 | Posted in Construction Techniques on January 12, 2003 05:14am
I have put a round vinyl window in a shower directly facing the shower head.We put the casing and jam extension in and now am trying to figure out how to totally waterproof this scenario.I am thinking of putting flex base all the way around the jam and sealing that in.I also thought of using layers of polyurethane to seal the jam area up but I don’t think it will build up properly around  the top.Any suggestions will be appreciated.
                              ANDYSZ2
I MAY DISAGREE WITH WHAT YOUR SAYING BUT I WILL DEFEND TO THE DEATH YOUR RIGHT TO SAY IT.
  1. xMikeSmith | Jan 12, 2003 08:57pm | #1
    the vinyl window was a step  in the right direction... for your jambs & sill . either tile or stone or corian... with a waterproof caulk like sika-flex
    Mike Smith   Rhode Island : Design / Build / Repair / Restore
  2. Fbart | Jan 12, 2003 09:04pm | #2
    I recently changed a window in my tubshower area, and instead or replacing the wood which was there, I used plastic brick mold, with a good caulk job.  It is not the usual look for trimming the inside of a window, but in this case, where it is behind a shower curtain most of the time it worked out fine.
  3. FastEddie1 | Jan 13, 2003 04:24am | #3
    there's a q&a in the current issue of JLC about flashing a curved-top window...might give you some ideas.
  4. Piffin | Jan 13, 2003 04:35am | #4
    Coming from a boating community, my frist thought is to layup fibregalss.
    1. ANDYSZ2 | Jan 13, 2003 08:22am | #5
      Piffin by fiberglass do you mean putting up a web tape and bondo it in place? Secondly if I take this route what type of paint would you recommend?
      1. Piffin | Jan 14, 2003 03:07am | #8
        Rather than bondo, I was thinking of web reinforcing and a boat repair type kit. Works a lot like bondo or West system repairs but with fibres to build depth then a finish coat of polyester Resin. Oil paint..
  5. Turtleneck | Jan 13, 2003 05:03pm | #6
    Advise customer to lower the showerhead. One of those telephone showerheads that slides up and down on a vertical pole will work wonders. The less water that hits the window the better. Unless they are absolute clean freaks (like my cousin Pat) shower windows get pretty skanky in a hurry.
    Not many alternatives with a round window except caulk all the seams and wipe up the water, but I'm sure there are hundreds of theoretical solutions.
    ( your logo here) Turtleneck
  6. Scooter1 | Jan 13, 2003 07:22pm | #7
    Window directly facing a shower head. While the window itself is vinyl clad, the framing underneath is raw wood, without any waterproofing. This application will leak, the framing will rot, and you will be replacing the whole shebang in about 5 years.
    I would have eliminated the window entirely. If you must have it, I would have relocated it.
    But you didn't and you have a nice vinyl window which will leak. At this point, I think I would remove the vinyl jambs and use mud, or use mud over them. I'd nail backer board over the sill. For the casings around the window, I'd remove them and again use mud. Waterproof the whole shebank with Laticrete 9235.
    Regards,
    Boris
    "Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1927
