Wax vs synthetic toilet rings
emaxxman00 | Posted in General Discussion on July 4, 2007 07:07am
The wax ring on my toilet basically felt apart (due to rocking I think) and rotted the wood sub-floor.  I am going to tear out the floor down to the joists and replace it.  I had vinyl over a plywood subfloor.  I have cast iron drain pipes and an intact cast iron flange.
Since the flange would only be even with one layer of plywood, it will not be level with the finished floor.  I was thinking of using one of these synthetic (Ultraseal?) rings that can compensate.
  • What’s the durability of these synthetic rings?  Greater than wax?
  • Do I need to add flange spacers so that the flange is level with the finished floor?
  • If I need to add flange spacers, how do you “seal” the space between the original flange and the spacer, i.e. do I caulk it?  Do I need to worry about a water proof seal?
Is there a better alternative than using a synthetic ring?
  1. rick12 | Jul 04, 2007 07:47pm | #1
    "Since the flange would only be even with one layer of plywood, it will not be level with the finished floor."
    If you are saying that the toilet flange will be slightly lower than the finished floor, I don't see why a simple wax ring would not work. The wax will fill the gap and prevent any leaks.
    Rick
    1. DanH | Jul 04, 2007 10:47pm | #3
      A "simple" wax ring won't work, but an extra-thick one will, or two of them stacked together.
    xxPaulCPxx | Jul 04, 2007 10:43pm | #2
    I've replaced every wax ring I've come across so far with the plastic sleaves that have the rubber washer at the top.  The washer seals to the lip of the toilet, and the whole thing provides a slight upward pressure against the botttom of the toilet so it stays sealed even with movement.
    Re-usable to, and no mess.  Never had a leak.
    Also a CRX fanatic!
    Parenting has always been a mix of sage life advice and inexcusable laziness.
    1. DanH | Jul 04, 2007 10:48pm | #4
      Yeah, we've had very few reports of the things, and some outlets stopped selling them, so there's not much word of mouth one way or the other. Good to here of some experience with them.
  3. roger g | Jul 05, 2007 03:34am | #5
    I'VE USED the foam ring a couple of times and like the other person said about having that constant up lift pressure. It is a fairly dense foam and as you tighten the nuts to compress the foam, the foam doesn't want to compress. I'm always petrified that I'm going to break the toilet if I tighten the nuts so I have never sucked the toilet down to the floor nice and tight. The toilet ends up rocking abit which doesn't look professional. Has anyone ever tested to see how much pressure it takes to break a toilet at the bolt hole?
    The foam gasket came into my mind a few days ago after laying some electric in floor heating in a customers home. I wondered if the electric mat was too close to the closet flange and was concerned about the wax seal melting as per some horror stories. A foam seal would solve that problem without a doubt.
    roger
    1. DanH | Jul 05, 2007 03:46am | #6
      The ones I've seen aren't a foam gasket but rather two giant O rings and a couple of large diameter plastic tubes that the O rings "roll" on.
        xxPaulCPxx | Jul 05, 2007 04:18am | #8
        Yes, the one you describe is exactly the one I was talking about.Rebuilding my home in Cypress, CA
        Also a CRX fanatic!
      2. roger g | Jul 05, 2007 06:02am | #9
        Hmmm. I've never seen those before. The ones I've used looked just like the wax one but foam.
        roger
    2. xMike | Jul 08, 2007 02:33am | #14
      Have you tried setting the seat cover down and having someone substantial sit on the unit whilst you tightened away? Seems like that would take out the play to the floor, ......and if not - hummm...better check to see if the toilet rocks WITHOUT the seal in place ... too high a flange height, possibly?Having replaced a rotten floor under a toilet with a too high flange, I now test the toilet/flange/floor spacing BEFORE I put in the seal.Mike D
      1. grpphoto | Jul 08, 2007 04:11am | #15
        Mike has a good point. In addition to that, I once bought an American Standard Plebe unit that had a warped base casting. I had to do a little surgery with a masonry blade to get it to sit solidly.George Patterson
      2. roger g | Jul 08, 2007 05:40am | #16
        Actually that is a pretty good idea though I'm usually alone when doing these sort of things. It's been a few years since I used a foam one but if I ever used one again I would try to get the toilet "down" first then tighten the nuts rather than trying to suck it down with the nuts. Good tip. thanks.
        roger
    AaronRosenthal | Jul 05, 2007 04:11am | #7
    I'm another one who replaces or installs "new" with the Fernco gaskets.
    I put one in my own house, and a whole bunch more in customer homes. I'm not a plumber.
    I have never had a leak. In fact, one of my foster kisds did the impossible - he plugged my Toto toilet with 2 rolls of toilet paper. I had the toilet apart and cleared out, and back on with the re-used seal nice and tight in 35 minutes.
    Did I mention, it was at 11:45 pm? Nobody was open and an emergency plumber would have cost me $200.00.
    I'll use them every time.
    Quality repairs for your home.
    AaronR Construction
    Vancouver, Canada
    1. myhomereno | Jul 07, 2007 10:23pm | #13
      Wasn't it nice when the HD on Terminal Ave was open 24-7. I don't think you would have found a Fenco there but you could have gotten a wax seal.Martin
  5. BUIC | Jul 05, 2007 06:15am | #10
      You also need to address the rockin' toilet.
      I've always set mine in a line of sanded grout, under the perimeter of the base, no matter what the floor.
      When the toilet doesn't rock it's easier on the seal and bolts/flange too...buic
    1. DanH | Jul 05, 2007 06:30am | #11
      Yeah, that my rule whenever I set a toilet -- do whatever it takes so that there is ABSOLUTELY no rocking.
  6. emaxxman00 | Jul 07, 2007 03:16am | #12
    Thanks everyone for your help.  For more on this continuing saga, see this thread:
    http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&ctx=1&cacheTag=15-5&msg=91997.1
  7. User avater
    Dinosaur | Jul 08, 2007 06:22am | #17
    There is an ABS/wax combo ring made specifically for this application. It is a extra-thick wax ring with a flanged 4x3 ABS 'nipple' that extends down through the new flooring thickness into the existing 3" waste pipe, be it lead, ABS, or CI. It is fool proof, cheap (about $5), and a no-brainer to install.
    Dinosaur
    foolish men call Justice....
