Weather proofing holes in exterior wall
How do you seal house wrap when you have to cut a hole through an exterior wall? I have seen many techniques for flashing around pipes when there is no siding, but how can you seal the house wrap to the pipes when there is existing siding?
Well,
Depending a little on the type of siding, get a good grade of Urethane caulk and before you shove the pipe through the hole, goop up the perimeter of the sheathing so that's sealed. Insert pipe, do a beautiful job of caulking the perimeter of the pipe to the siding.
Monitor over the years and redo if necessary.
