Well storage tank leaking
icerunner | Posted in General Discussion on March 9, 2016 04:02am
I just added a 1000 gallon well storage tank. The two inch threated pipe fitting is plastic and so is the male threade thing I’m attaching.
I put both teflon tape and plumber’s paste (says for plastic and metal) on it and it leaked. The guy at the local hardware store, not a box store, said just wrap it four times with teflon tape – it still leaks.
Although it is a minor leak, it is still annoying. I’m about ready to just glue it in there.
Any ideas would be great.
  1. oldhand | Mar 09, 2016 06:03pm | #1
    don't give up easy....
    My first thought would be to try a new male threaded thing if at all practical.
    coonass | Mar 09, 2016 08:49pm | #2
    icerunner,
    Wrap it 10 or as many as it will let you thread the fitting on.
    KK
  3. junkhound | Mar 09, 2016 09:59pm | #3
    a.  like oldhad says, new male fitting - plus, if pvc, clean the mold lines off with a pipe die, it you dont have a 2" die, clean the mold lines off carefully with a knife
    b.  pipe dope on male threads, 3 or more wraps of 3/4" wide or wider tfe tape, more pipe dope
    never had one like that leak.
    tighten until you see the pvc slightly deform under the wrench flats.
    deadnuts | Mar 09, 2016 10:49pm | #4
    YOu might try wrapping the entire fitting with self fusing silicone tape (ex. X-treme brand tape).I've made some emergency repairs with this stuff under 50 psi pressure and it's held way longer than I though it would. If it doesn't work at least it is easy to cut off with a razor knife w/o leaving any tape residue.  This way you're back cleanly at square one and only out the cost of roll of tape and the time it took to wrap it up.
    1. icerunner | Mar 17, 2016 03:55pm | #9
      Thanks! The self sealing tape did the job!
  5. user-1116010 | Mar 10, 2016 07:58am | #5
    thread like........
    I suggest using some ball wicking wound tightly around the threads, and then 5 - 6 wraps of quality 3/4" teflon tape. Some types of plastic do not seal well with liquid pipe joint compounds. I would also put a small piece of pipe, or a snugly fit wooden dowel into the adapter socket to prevent distorting the fitting as you tighten it.
  6. icerunner | Mar 10, 2016 11:43am | #6
    Thanks so much for all the repiles!
    I did try a new male threaded PVC with no avail. Some great ideas that I'll try.
    Again, thanks.
  7. DanH | Mar 10, 2016 04:55pm | #7
    On at least one occasion I found that I simply needed to tighten the fitting quite a bit tighter than seemed "right".  You need to get the connection tight enough that the plastic deforms slightly.
    But I've also had actual defective fittings a couple of times.
  8. florida | Mar 14, 2016 11:35am | #8
    If nothing else works try a galvanized nipple with tape and thread dope.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
