Went up above…….
Sailfish | Posted in General Discussion on March 16, 2005 11:50am
into the trusses of my shed to get some stuff down that I had stored there. I found a bunch of oak pollen sacks right down the middle. Apparently they are blowing up under the ridge vent (metal roof) and into the shed. It’s a 9/12 pitch.
First how the heck? Second, no water appears to be getting in. Third, what is an acceptable gap between the panels at the the top? Lastly, what can I do to stop it?
“Have you seen my baseball?”
    Sailfish | Mar 17, 2005 04:58pm | #1
    btt
    "Have you seen my baseball?"
  2. Matt_S | Mar 17, 2005 07:41pm | #2
    Wind will blow all kinds of stuff in through the ridge cap. Buddy of mine has a metal shop with an old truck parked directly under the ridge. There is a 12" wide layer of leaves and dust on the truck where it falls downs from the ridge.
    I have no clue with the amount of "acceptable" gap.
    There are foam blocks that can be installed to prevent stuff from being blown in. Check with a metal roofing supplier.
    CapnMac | Mar 17, 2005 07:46pm | #3
    You may have to post us some pics.
    Do not use a really really strong glue and span really tough nylon window screen across the bottom of the ridge vent (it turns into a very ugly tale later on when the screen fills up with crud).
      GoldenWreckedAngle | Mar 17, 2005 08:42pm | #4
      Nothin' like the voice of experience, eh Cap?
      1. FHB Editor
        JFink | Mar 17, 2005 09:32pm | #5
        ...hope you don't get any oak trees growing in your attic!
         Justin Fink
        FHB Editorial
          JeffBuck | Mar 18, 2005 04:23am | #12
          InDoor Oak Farm .... don't be so fast to judge .... big money in speciality woods ....
          Jeff  Buck Construction
             Artistry in Carpentry
                  Pgh, PA
        CapnMac | Mar 17, 2005 09:43pm | #6
        Or the "vision" of experience, walking around getting called "pop eye" for having crud that won't quite get out . . .  (or leaving a site saying "I've 'ad all I kin stands, and kin't stands no more . . . )
        Oh, and using more than long-enough screws through the metal roof into the skip sheathing, and having them poke through makes for a loooooovvvvely work environment--but that might be the "scars of experience" . . . Occupational hazard of my occupation not being around (sorry Bubba)
      Sailfish | Mar 17, 2005 10:04pm | #7
      Aye Capn, here's the pic
      What I don't understand though, is if it will blow up under the shed roof, how will I kep it from blowing up under the house roof (i'm going metal  on it too)????
      View Image-----------------------------------------------------------------------------
        CapnMac | Mar 18, 2005 12:02am | #8
        Egads!  Another "should I vent the roof question?"  No, seriously (I'm tryin', I'm tryin')--there's not many options that leap to mind.  Any "filter material" you use has to be replaceable, which means it also has to be accessible (wow, a link back to the "what should i over/under build thread).
        Most of the info/specs I've seen seem to assume that the attic (read, ventilated roof) spaces breathe the same air as outside--hard to keep some of the things in that air out of the ventilated areas.  I've seen ridgevent installations with gutters under them, too.  Means we're likely to see just about anything.
        Now, around here, I'd be more worried about yellow jackets or red-faced hornets taking up residence in the shed than pollen--but that's just my experience, others differ.Occupational hazard of my occupation not being around (sorry Bubba)
      2. Matt_S | Mar 18, 2005 12:48am | #9
        What? Is my post invisible?
        Fer cryin out loud, check with a roofing supply house. They have the stuff you need.
          Sailfish | Mar 18, 2005 04:17am | #11
          Sorry Matt. How the heck did I miss your post. My bad. Friends?
          I will take your advice-----------------------------------------------------------------------------
          1. Matt_S | Mar 19, 2005 12:59am | #13
            Awe shucks! :)
    coonass | Mar 18, 2005 02:20am | #10
    saifish,
    Matt was right. Check with your metal supplier for some vented closure strips.
    Sealtite makes one.
    http://www.sealtite.com/multivent.htm
    KK
Old House Air-Sealing Basics
