wet bed tile
user-216201 | Posted in General Discussion on July 9, 2004 04:54am
Hi everyone ,
Could somebody tell me the proper type of sand and the ratio of sand to cement for a  good solid wet bed tile floor?
  1. JerBear | Jul 09, 2004 05:56am | #1
    The usual 3 sand to one portland.  Throw in two of masons lime to make it more like a mortar and more workable if you want.  I use regular washed pit sand, or even playsand if you want.  Dry mix your ingredients and add just a little water to make it the consistancy of damp sand, like at the beach, level it out.  If you want to lay the floor and tile in one shot, sprinkle a little pure portland over the area and then sprinkle with water to make it a little creamy on top.  Lay in your tiles. Or...if they're big tiles, butter up the back of each tile with a wetter mix then lay the tile in on top of the damp mix.  Level it as you go and take a 12"x12" piece of flat three quarter ply, lay it on top of the tile and tap it with a hammer to 'set' the tile.  Or....wait a day and  use thinset on top of the cemet floor after it has cured...that's the easiest.
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
