wet hardieplank
louieg | Posted in General Discussion on January 28, 2007 11:28am
I have begun installing the hardie plank that I pre painted several weeks ago. Today when I took the plastic off that had been covering it I discovered that some of the pieces, roughly one third, were wet for a quarter or a third of the board. My question pertains to whether or not the freeze thaw cycles in va. at this time of year will give me any trouble. I know that the boards may contract a bit as they dry and that is ok as I have allowed for that. What I am most concerned about is delamination. Does anyone have any experience in this realm?
  1. WayneL5 | Jan 29, 2007 12:58am | #1
    You may want to contact the manufacturer to get a better answer.  There's reason for optimism, though.  Before I spec'd Hardie for my home I placed a sample shingle, nailed to a board, outside for an entire winter to experience all the weathering, including freeze/thaw.  I examined it closely and saw no visible degradation.
  2. dovetail97128 | Jan 29, 2007 01:15am | #2
    When hardie first came out we used to spray it with water when cutting to keep the dust down. No adverse affects that I am aware of and my own house was done that way. I woudn't worry about it.
    Edited 1/28/2007 5:38 pm ET by dovetail97128
  3. Westcoast | Jan 29, 2007 02:57am | #3
    I have a two foot piece that has been soaking in a bucket full of water for the last couple years.
    Take it out now and then and throw it on the grass for a few weeks and then back in. Been through lots of freezing temps this year while being fully saturated with water and not a thing wrong with it. This product is bulletproof it seems.
  4. Brian | Jan 29, 2007 03:22pm | #4
    My experience has been that Hardie will bend more readily when it is soaked, but this is only an issue for installation.  I broke a few soffit panels this way...
    Treat every person you meet like you will know them the rest of your life - you just might!
  5. moltenmetal | Jan 29, 2007 03:44pm | #5
    I had the same problem:  my order was dropped in October and had to over-winter under a tarp.  Turns out it was a very leaky tarp!
    I got some serious surficial staining on a few pieces at the top of the bundle, and we broke quite a few pieces handling it too- it is way more flexible and likely to break when wet than when dry.  But neither water itself nor freeze-thaw seem to affect it much.
