What am I doing right? – Cellulose
I’m blowing dense pack cellulose in 2×4 walls and I just did some calcs and figure I’m getting 4.75lbs/cu. ft. The last time I did this I was blowing the sheetrock off the walls at 3 – 3.5lbs. No such problems this time. I’m happy with the results but I don’t know what I’m doing different. Any ideas?
Jerry
Change in the value of G.
Better/thicker drywall, maybe... or screws vs nails.
Troy Sprout
Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it."
-- Thomas Sowell
maybe instead of the sheetrock, you're blowing the sheathing off.... have you been outside lately ?
Has he checked the basement?
People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarck
Ck the bag weight. That Coccoon stuff at HD is only 22 pounds a bag.
Joe H
You guys are all very funny :-) Mike - you made me look! Sheathing's still there.Joe - made adjustment for the smaller bags; last time I did this I think the bags were almost 30lbs and cost 30% less.Dan - "...value of G" huh?Hack, All - I did put more screws this time, so I guess that helped, but technique wise, I don't know how I'm getting so much in this time. Is the density I'm blowing at typical? Maybe I just did a poor job last time.Jerry
Just don't slam the door on the way out.I would hate to see all of the wall just Pop Off..
Hey every group has to have one. And I have been elected to be the one. I should make that my tagline.
seems pretty high density to me... i'm usually happy with anything over 3Mike Smith Rhode Island : Design / Build / Repair / Restore
I'm with Mark, that density is really high, 3+ lbs per cubic foot is plenty, I don't think more is better in this case. Re-check the math.Garett
Mike,I think you usually do the Mooney wall thing, but have you blown into existing walls and checked your density? I'm wondering if I have the slide plate on the blower closed too much. It's going very slowly.Garett,Standard 2x4 construction gives me 2.72cu ft/bay (92.5 x 14.5 x 3.5). The bags are actually 21.4lbs each. I blew 16 bags into 28 bays which gives me 342.4lbs into 76 cu ft or 4.5lbs/cu ft (and the drywall's still on) ;-)Jerry
we do a test run every once in a while...
wether it's mooney or conventional, it usually comes out to about 3 #
we've got a small bedroom comming up... walls only... drywall... blow, then tape....we'll test the density on that and let you knowMike Smith Rhode Island : Design / Build / Repair / Restore
I might be tired and slow but.... 28 bays @ (3.5*14.5*92.5)=28 bays *4694.375 =
131442.5 cubic inches 13144.25 ci / 144 ci/cf = 912.795 cf
912.8 cf / 342.4 lbs = 2.665 lbs/cfStill good 2.5 in the min to eliminate settling...Garett
Garett,I'm gonna go with just tired. ;-) Just kidding, I appreciate the help. If you blew 342lbs into 912 cu ft you would have .375 lbs/cu ft. You went wrong in the conversion to cu ft. There are 1728 cu in to a cubic foot (12 x 12 x 12 = 1728).
So: 131442.5 cu in / 1728 = 76 cu ft
342.4 lbs / 76 cu ft = 4.5 lbs/cu ft
Your Right... And that's some tuff drywall. Merry Christmas
