What are those box type things that go around the electrical outlet boxes for insulating and vapor barrier purposes? I’ve seen them on a t.v. show. Never saw them in the real world. Do many people use them? Are they worth it?
In this FHB Podcast Segment, the team chats about the best way to build a paintable surface over an old wall.
A Modern California Home Wrapped in Rockwool Insulation for Energy Efficiency and Fire ResistanceRelated Stories
Doobz
They save a lot of fussing compared to wrapping the boxes in VB plastic and trying to make a good seal with that.
Aren't they used in the US?
Ron
Lessco is one I know of, if I have the spelling right.Edit: yes, that's it. URL is: http://www.lessco-airtight.com/
Edited 12/11/2008 4:43 pm ET by DickRussell
Thanks. Those are the kind I saw on an episode of Hometime. Looks like they would have had to go on prior to wiring. I also at one time saw a foam type that you glued to the wall but can't dig up any information on that kind.
How about lowry pads? Used out here for firewalls and sound transmission.
http://www.google.com/search?sourceid=navclient&aq=t&ie=UTF-8&rlz=1T4ADBF_enUS280US280&q=lowry+pads Mike
Small wheel turn by the fire and rod, big wheel turn by the grace of god.
I would think that a pad on the back of the electrical box wouldn't be quite as good as having the box mounted inside an outer plastic box like the Lessco. I would think that the sheetrocker's rotozip running around the outside of the electrical box would leave more air leak space around the box than a sticky pad on the back would seal.
We call them putty pads, & use them for fire protection mainly around ice maker & auto washer boxes.
http://www.energyblock.com/
Used them the first time this week. Goes on quick, easy to modify - can't imagine using anything else. Cost of shipping is included when you order 10.
tek. Thanks. I remember seeing those somewhere but could not find them anywhere online. Do you have to install them prior to wiring?
No problem. They can go on after the wiring. You just press the box where its going and the wiring leaves a small impression on the foam. Pinch out the foam at the wire and install it. They recommend installing them with latex caulk, but I used some with foam and some with acoustical sealant.
There was one 2 gang box I had that was tight between studs. I mounted the switch box, then the foam (had to cut it and half and glue it back with foam) then ran the wires. That was easy as well.
Depends on "where."
Here at 29N, the VB goes to the outside where the heat and humidity are 9-10 months of the year (and we want it drier on the inside).Occupational hazard of my occupation not being around (sorry Bubba)
Plastic electrical boxes with seals are allot easier than mess'n with vb and tape ..
Standard use here north of 49, for all exterior wall electrical except maybe for 2 x 4 wall ( garages) ( or double wall systems with VB between interior and exterior wall and all ecectrical runs on the interior wall / strapping ) ( standard framing here is 2 x 6 )where they don't let you get enough insulation behind the box. Some use the foam gasket type plastic box, but they are more $$.
IF IT WAS EASY, EVERYONE COULD DO IT !
What Wane said. For a few more cents per box, you can get ones with foam seals that you push your wire through. The foam keeps a tight seal around the wire. It's WAY less fuss than taping the plastic boots to the vapor barrier.
Scott.
Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.â€
