What do I use to repair a cracked ….
| Posted in Construction Techniques on August 2, 2004 12:04pm
I have a vertical crack in a poured basement wall. the source of the pressure causing the crack has been identified and taken care of, no movement over a 5 year period. I have used a SDS hammerdrill wwith a chisel bit to open the groove so it is now averaging 1-1.5 inches in depth and the material will have enough surface area to get good adhesion. It is a wall between the basement and attached garage, so it doesn’t see much water ( if at all) and has not leaked once. the other side was dug out and the area re-tarred before repouring the garage floor.
I am thinking of using hydraulic cement as it expands slightly wjen setting/curing and should result in a tight joint. Appearance is not a probem, that portion of the basement is just used for storage anyhow.
What’s the best repair material to use?
Thanks in advance for the help.
Stan
  1. DANL | Aug 02, 2004 12:20am | #1
    Hydraulic cement is what I'd use, for the reason you cited--it expands as it cures.
    1. smijal | Aug 02, 2004 02:43am | #5
      Thanks for confirming my thoughts Dano. Just wanted to check with others here before I chose one method and then found out there was a better /easier way . (Who says an old dog can learn new tricks?)
      1. junkhound | Aug 02, 2004 03:12am | #6
        For a really good bond, power (or hand) wire brush some of the cement paste onto the sides of the crack before filling.
      2. DANL | Aug 02, 2004 03:23pm | #7
        I agree that is worth seeing if there is something better or easier. Also good to get confirmation before going ahead.
  2. UncleDunc | Aug 02, 2004 12:34am | #2
    If it's not getting any larger and not leaking water, why spend any more time and resources on it?
    1. FastEddie1 | Aug 02, 2004 12:43am | #3
      why spend any more time and resources on it?  because he has already chipped it to an inch wide , and DW is probably complaining about all the spiders that are going to crawl into the house.Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
    2. smijal | Aug 02, 2004 02:41am | #4
      Before hogging it out it was about 1/4" to 3/8" wide already and had some crumbling edges, so it really needed to be repaired so it would look presentable.
      Edited 8/1/2004 7:43 pm ET by SMIJAL
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
