Hi folks,
I’ve been a subscriber to FH for quite awhile & finally have a question worth posing to you.
I’m planning to cut the slab in our basement around the perimeter and install a french drain that will empty into the existing sump well. Most of what currently drains into the sump comes from under the slab flowing around the outside of a cast iron floor drain which drains into the sump. We had 4 days of rain in late March that saturated the ground causing seepage between the foundation and the footer in the basement – just enough to ruin area rugs and make a huge mess. BTW, the house was built in 1968, and the basement has only one drain – 10 feet from the sump.
I did the new french drain on the outside of our last house and I do not want to go through that again. This time, as I stated above, I plan to cut the basement floor around the outside walls, install a 3″ perf drain in new gravel with landscape fabric wrapping between the mud & the gravel and pitch it to drain into the sump.
Here’s my question to you… to hedge against future water damage from the foundation leaking again at the footer, I am considering using a piece of COR-A-VENT to serve as a channel to allow any future seepage to drain into the french drain from the bottom of the foundation wall at the floor level. Have any of you ever done this? I can’t see why it wouldn’t work, but would like those of you that do this full-time to mull it over & tell me why it wouldn’t work.
Although I plan to seal the foundation at the floor with some kind of silicon sealer, I don’t want to do all the french drain work to have the water leak through the foundation again and puddle all over the basement.
Thanks for your time,
Brian
Bcanose:
The only way you can stop a leak in the basement is from the outside. Before you do anything find the water source. Once you've found it stop it. It must be stopped from the outside.
Good luck
Charlie
Charlie, it sounds like he has said that the source is a high water table passing in at the bond between wall and slab .
