What do you use to mark dark, wet wood?
TomMoen | Posted in Construction Techniques on December 23, 2005 11:26am
I’ve got a lot of deck stairs to build out of pressure treated hem-fir. (Hem-fir?) Those of you on the west coast know what I’m talking about. When wet, I simply can’t see my pencil marks well enough to cut accurate jacks. How do you overcome this? I’ve searched for white or yellow leaded carpenter pencils with no luck. I have tried a red lead carpenter pencil with unsatisfactory results. What say you?
    dieselpig | Dec 23, 2005 11:37pm | #1
    Tom,
    I have just the thing for you.  But sadly, I'm on the East Coast so I'm not qualified to answer the post.  Oh well.
    Just kidding.  Believe it or not, our treated lumber is wet too.  I can relate.  Sometimes the silver Sharpies will work.  Other times the best thing to do is use a knife or an awl to mark your cut lines.  If you find something foolproof, be sure and share.  I'm sure it's a common problem for all of us.
  2. Jen | Dec 24, 2005 12:47am | #2
    how about chalk? or for a finer line than chalk, a white colored pencil?
    1. TomMoen | Dec 24, 2005 04:24am | #10
      I have not tried the white colored pencil, but I want to. I think It'll be brittle, but perhaps I can be gentle enough. I wish someone made carpenter pencils with white lead. I need a fine line, not a lumber crayon. Hey, maybe I can sharpen a yellow lumber crayon to a chisel tip. That's the ticket. It'll probably crumble, but I'll try it. Hey Dieselpig, don't you eastern boys use pressure treated SYP? That's light colored I thought. I'll look at the silver sharpies.
        dieselpig | Dec 24, 2005 04:29am | #11
        Yes, we use SYP PT, but it almost always comes soaking wet and black like the hem-fir.  (Very dark green actually) I have the same problem marking stringers.  Sometimes the silver Sharpies will take, sometimes they don't.
        I've tried getting a decent line out of lumber crayons (aren't they called a kreel or a keel or something?  I forget)  but like you said, if you can get it sharp enough it's probably gonna break pretty quick.
        Don't give up on using a marking knife, a scratch awl, or even a small nailset.  9 times out of 10 that's what I end up using rather than fighting an uphill battle with a topical marking.  It makes for a pretty good cut line most of the time.
          Sphere | Dec 24, 2005 04:47am | #13
          Yer nutzo..use a goose quill and imported india ink..geeze..framers!
          Have a cool yule..love ya
            dieselpig | Dec 24, 2005 04:55am | #14
            Right backatcha brother.
  3. Jamie_Buxton | Dec 24, 2005 01:35am | #3
    Lumber crayons.   They write on dry wood or wet wood, and can be bought in light colors.   For example
    http://www.dixonticonderoga.com/index.cfm?fuseaction=shop.product&prdIndex=176&CFID=1372149&CFTOKEN=67110834
      dieselpig | Dec 24, 2005 01:39am | #4
      Kinda of inaccurate for a stair stringer, don't ya think?  Whatcha cutting yer stringers with a Stihl?
      1. DougU | Dec 24, 2005 03:04am | #6
        We mock what we do not understand!
          dieselpig | Dec 24, 2005 03:24am | #8
          Wouldn't be the first time..... enlighten me sensai.
          1. DougU | Dec 24, 2005 05:47am | #15
            I have no idea, that's a line from Spy's like Us.
            Dan Akroyd and Chevy Chase are about to operate on someone and they haven't a clue what the're doing, some one questions there technique and that's what Dan says to them!
            dieselpig | Dec 24, 2005 05:51am | #16
            That one went right over my head Doug.   My bad.  Rough week and all.
    zak | Dec 24, 2005 01:40am | #5
    yellow lumber crayons. most good hardware or fastener stores seem to have them. they're always breaking though.
    Actually my preference would be a scribe or an awl to scratch a nice line, if it was important to be exact (like stairbuilding would be).
    zak
  5. PeteVa | Dec 24, 2005 03:23am | #7
    Here in the country deck screws make good scribes, fit right up against a framing square. One less thing to forget to pack up when you're done.
  6. davidmeiland | Dec 24, 2005 03:28am | #9
    Dry the surface of the wood with a rag and then a heat gun. Then use a carpenter's pencil to do your layout. Doing layout right on a soaking piece of black PT is not gonna work very well.
  7. User avater
    Sphere | Dec 24, 2005 04:33am | #12
    Put away anything else that makes a line less than .002 , use the utilty knife god gave you, multi-task or die.
  8. 4Lorn1 | Dec 24, 2005 06:28am | #17
    You might try these:
    http://www.leevalley.com/wood/page.aspx?c=2&p=32540&cat=1,42936
    I'm thinking the red one might work. They say they write on damp wood. They, according to a friend, are not kidding when they say they are indelible so you might need to make sure you only mark the drops.
    White china markers, grease pencil, or silver sharpie might work but I suspect if the wood is more than slightly damp they aren't going to make a mark consistently.
    1. TomMoen | Dec 24, 2005 07:40am | #19
      Well lookee there, a red one. I have a black one, but not red. Good find.
      1. JBanyan | Dec 27, 2005 08:09am | #35
        welders/steel cutters use a soapstone for marking on dark steels etc
         it makes a white line and you can buy it at any welder supply store
  9. User avater
    jazzdogg | Dec 24, 2005 06:40am | #18
    Spent a pleasant weekend working with a crew of Japanese timber framers (talk about precise and meticulous!) and they used two tools to assure accurate joinery: A snapped a silk ink line (like a chalk line) that left a line that was easy to see and follow, and a bamboo ink pen that left a line like a Sharpie fine point - accurate enough for tight mortise & tenon joints, scarf joints, etc.
    These tools are available from http://www.hidatool.com
    http://www.japanwoodworker.com
    http://www.japanesetools.com
    -Jazzdogg-
    "Don't ask yourself what the world needs. Ask yourself what makes you come alive, and go do that, because what the world needs is people who have come alive." Gil Bailie
    1. TomMoen | Dec 24, 2005 07:48am | #20
      Do you mean the ink pens with the felt chisel tip? I can just see the ribbing I'd get for using it; marking a couple lines....dipping in the ink bottle! Oh yeah. In reality, I think its too slow and fragile. I need to be able to throw it in my bags.Any kind of snapped line will not work. You lay stairs out using a framing square. I'd get some REALLY funny looks if I tried to snap a line using the square, and I'm sure I'd be commited to the nuthouse if someone caught me trying to snap the outline of the pattern jack onto the next 2x12.
  10. notascrename | Dec 24, 2005 09:10am | #21
    seems to me on BT that too often guys  spend hours trying to answer the wrong question. seems to me wet frozen lumber is a nationwide problem this time of year,duh, its winter. I get my press. trtd. lumber from a yard that keeps it all under cover. unbundled,dried and re stacked. yeah I pay more for it, wear the same set of gloves all day too.[ actually I havn't driven a nail on a job in years]. if everybody told the lumberyard the straight-up truth, things might improve, Ive noticed that one person can make a difference. I might be spoiled,I can go the lumberyard and tell them just exactly how the hoo it's going to be and thats how it is. [ sometimes we wrangle about it a little].I dont build tract house, don't build condos, don't build Mc Mansions. couldn't make a living framing dog houses, but my bill at the lumberyard runs 30 to 80k every month. I'm still the same moron stumbling along behind the wheelbarrow full of concrete that I was 40 years ago,go figure---
  11. User avater
    MarkH | Dec 24, 2005 03:29pm | #22
    Try a stabilo white pencil from an office supply or art store. The grease pencils may work, but are probably too soft.
  12. junkhound | Dec 24, 2005 04:24pm | #23
    Deck screw and utility knife have been mentioned, how about a plain old NAIL?
    Used nails on all kinds of lumber since a kid., always have one, never get dull, cheap, as accurate as a carp pencil.  If you are building furniture quality accuracy cuts for yur decks, then go with the utility knife fer sure.
    1. TomMoen | Dec 24, 2005 09:34pm | #24
      Thanks for all the suggestions.A knife or nail or screw will not work. Can't see it.I'll report back next week to let ya'll know what worked.
      1. junkhound | Dec 25, 2005 11:55am | #28
        Try bifocals, or reading glasses??
          JeffBuck | Dec 26, 2005 11:00am | #29
          I'm thinking just push harder?
          push hard enough ... it'll cut thru ...
          Jeff    Buck Construction
           Artistry In Carpentry
               Pittsburgh Pa
  13. SBerruezo | Dec 25, 2005 06:55am | #25
    I've noticed that some pencils write better than others.  One of our local lumberyards has a couple kinds of pencils, one won't even sharpen; they just fragment.  I would try getting a few pencils from different suppliers, that might do it.  Maybe some colored pencils.
    Young, poor, and eager to learn
    1. Snort | Dec 25, 2005 07:42am | #26
      Call me old fashioned and blind, but try sticking a piece of masking tape where you wanna cut, make a mark on the tape, stand upside down on one leg, squint yer eyez, hold yer breath, and dang, hope for the best<G> Hey, pocket doors can't come off the track if they're nailed open
  14. PhillGiles | Dec 25, 2005 08:26am | #27
    Bright yellow fibre tip pen from an artists' supply store. I bought the Faber-Castell last time because it was cheap; I'll probably buy the one from the company that makes the architectural drawing pens (Ortho... something) next time.
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  15. mike4244 | Dec 26, 2005 06:02pm | #30
    Buy the pencils for children, the big round ones. The lead is softer and marks better than a #2 lead on wet lumber.These pencils are about the same length ,but the diameter is about 3/8".
    mike
      Sphere | Dec 26, 2005 07:37pm | #31
      BUY Them?  I shake the little tykes waitin for the school bus every Tuesday...I hold em by the ankles, and get milk money at the same time.  Check the back packs too, some are getting smart and have a secret stash.
        dieselpig | Dec 26, 2005 07:46pm | #32
        I think I saw that on "Tips and Techniques" in last month FHB.  LOL.
    2. TomMoen | Dec 27, 2005 12:12am | #33
      Just to be clear: I can write on wet wood fine. I have special pencils for that (each yard has different leads that each have their individual strengths). Its the "dark" part that I'm having trouble with.Anyway, its time to get crackin. In few hours I'll find out what works best. Thanks fellas.
  16. User avater
    Soultrain | Dec 27, 2005 06:13am | #34
    I always use my pocket knife for marking.  It gives a better line than a pencil anyway.  The pencil line gets fatter each time you use it.
Mortar for Old Masonry
