I know framers probably don’t have a lot of use for handplanes; and woodworkers never seem to have enough. What do you consider the most useful hand planes for general remodeling and basic trim carpentry? What are they , and what do you use them for?
Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
I use a #5 jack plane from time to time. Mostly for woodworking, but occasionally for shaving down a door.
And a small, low angle block plane for trim work. My favorite is a Stanley # 60 1/2.
I concur with the jack plane and block plane as the first two. After that, I'd add a rabbet plane. The Stanley No. 78 is a good one, for reasons I'll explain below. You won't use it often, but, when you do, you'll be grateful you have it.Two examples, both siding related:1. I was installing horizontal wood lap siding on an outbuilding on our Victorian property. The siding on one side of a window didn't quite match up with the siding on the other - one side was about 1/8" higher. A couple of minutes with the rabbet plane, shaving off the top of the high siding, solved the problem.2. My son was replacing some "tear drop" horizontal lap siding (this is his term; don't know if it's a standard term) on his landlord's place. This is not a common siding pattern, and the new siding was subtly different in dimensions from the old; he was able to taper-plane the rabbet on the lap to blend it in.The No. 78 is neat because it's got a bullnose position for the iron for when you need to get into tight spots.Some people like rabbeting block planes, but these are a lot pricier.Find a good field sharpening system: oilstones, water stones, sandpaper on MDF or glass; lots of systems.Bill, who has just a few planes - stopped counting at 50, so I would never have to give a precise answer if LOML ever asks, "How many danged planes do you have, anyway?)
I recently bought my first BedRock, a #605. It was a little worn, so I'm still in the process of fettling it. I'm looking forward to putting it thru its paces.
Never heard that term."Put your creed in your deed." Emerson
old term for tuning a plane, used by us old carpenters
I have a block plane in my box and a small trim? plane.
I also find it convienent to have a small hand power plane.
Will Rogers
I dont use alot of planes, but I tell ya when I need to shave something inna hurry I use a block plane
I really like planes. I'm like Houghton- I don't know exactly how many I've got. I do know I've got 8-9 block planes, and I'm sure I'll be buying more. I have a fetish for block planes.
Anyway, now that you know more about me than you wanted LOL...
I carry 2 block planes in my van, a regular a and a low angle. Partly because they both have there uses, and partly because when one hits a nail, or gets dull, I can pull out the other one.
I also have 2 rabbet planes, a Stanley 78, and a smaller Stanley; I don't know the number. The 78 I use for any rough kind of rabbeting; the smaller one I can carry in my tool belt if needed, and is handy sometimes.
I also have a Lie-Nielson butt mortise plane in my van. Its great if I need to mortise in a few hinges, or strike plates, and don't want to make a lot of dust. And its surprisingly fast.
Whatever plane (s) you have, its important to keep them sharp. I've seen guys take one out of the box, and try to use it. Then say the tool's a piece of cr*p.
edit to add: the 2 block planes I carry in my van are both Records. They were definitely higher quality than the Stanleys available at the same time. While Record planes aren't made anymore, Stanley has come out with new, improved models. From what I've read, that's actually true. Or get Lie-Nielson or Lee Valley planes. Both are excellent quality, and won't need hours of work to tune them up.
Edited 8/6/2009 9:08 am ET by Shep
I concur on the butt mortise plane. This is one plane that you can make for yourself in an afternoon: http://www.woodcentral.com/articles/handtools/articles_114.shtmlBill Houghton
Nice work!
Basic is a low angle block plane. Stanley is good. Putting a fine edge on the blade is important. Here's a good method and a simple tool to help do that. https://home.comcast.net/~rexmill/sharpening/scary_sharp/scary_sharp.htm
I keep a Lie Neilson Bronze Low Angle block plane in my pouch when trimming. VERY useful for trueing up oddball corners and breaking sharp edges. Bought one for a buddy I work with alot for christmas just so he would have to keep borrowing mine. There a mite expensive but worth every penny. The other one I use on the job is a full size block plane. It's just big enough to shave a door edge. I keep them sharp on the job with a DMT Duo-Sharp diamond stone.
