What have I got here?
2leftfeet | Posted in General Discussion on October 16, 2006 04:25am
I replaced a window this weekend and found the house is sheathed with a fiberboard type material, literally marked “INSULATING SHEATHING” it seems the vapor barrier is integral to the material. In places where it had gotten wet it had literally turned to powder so I cut out the bad parts and replaced with OSB and #15 felt.
The house was built in the early 70’s and the siding is vertical cedar with a tongue and dado type of set up.
So what is this stuff. Does it have asbestos in it? Should I bother replacing as much as possible, or just the bad parts?
Here is a poor quality photo (a crop from my cell phone camera).
I finished this window replacement already but I have 10 more to go.
Thanks in advance for any leads.
  1. stevent1 | Oct 16, 2006 04:28am | #1
    Pic did not post
  2. 2leftfeet | Oct 16, 2006 04:39am | #2
    DOH the photo did not go
      BarryE | Oct 16, 2006 04:41am | #3
      fiberboard or we used to call it beaver board
      Barry E-Remodeler
    2. DanH | Oct 16, 2006 04:49am | #6
      Basically looks like fiberboard "insulating" sheathing. However, is the white near the window corner from the inside of the sheathing, or is that something else?
      1. 2leftfeet | Oct 16, 2006 05:10am | #8
        The white near the corner is the new sill, the camera blew the color out white.
    IMERC | Oct 16, 2006 04:43am | #4
    just the bad parts.. all if you like..
    it looks like Homosote... (tar and shredded paper)
    WOW!!! What a Ride!
    1. DonK | Oct 17, 2006 03:49pm | #20
      IMERC-
      Not to be picky, but Homasote doesn't have any tar in it. It's a light grey material all from compressed cellulose.
      Don K.
      EJG Homes      Renovations - New Consruction - Rentals
        IMERC | Oct 17, 2006 09:11pm | #22
        Saran wrap and kleenex..
        be picky..
        that is what makes this place great..
        1. DanH | Oct 17, 2006 09:46pm | #23
          I'll have to take an aspirin before I can figure that one out. The guys on the other side of the wall are tearing out sheetrock and my head is pounding.
            IMERC | Oct 17, 2006 10:18pm | #24
            two generic names to go along with the Homasote......
            and an invite to be picky..
            IMERC | Oct 17, 2006 10:22pm | #25
            Celotex and Homasote from the late - late 50's - early 60's other than the printing on them were very similar to include the asphalt impregnation...
            sure remember it that way..
  4. DanH | Oct 16, 2006 04:46am | #5
    Describe the stuff a little better -- color, texture, layers or uniform structure, etc.
    Unlikely to contain asbestos, I'd think, but others here may recognize the specific material and know better.
    Commonly used in this era was an "insulating" sheathing composed of loosely-compressed wood fibers. I've heard it called "beaverboard" around here, but I believe that's an incorrect attribution. It's generally brown or black, considerably lighter and softer than OSB. Does not include a vapor barrier (which you don't want outside anyway) but is mildly good at shedding water (with a sort of tarry outer coating).
    The stuff I've seen of this nature is reasonably water-resistant -- it won't disintegrate unless soaked repeatedly or for long periods of time. So if you have some of it disintegrating you'd be advised to check how sufficient your flashing is.
    1. 2leftfeet | Oct 16, 2006 05:16am | #9
      the "loosely-compressed wood fibers" describes it best. there are essentially 2 layers. 5/8" of the fiber board, light grey/brown in color then a 'skin' of black papery felty stuff that tears or crumbles like a piece of kids construction paper that has been out in the weather for a couple of weeks.
      The window being replaced was a single pane aluminum slider that had been condensing/leaking for at least 30 years. The sill plate and the trimmer stud were totally rotten too.
      So I can just replace the bad bits then?
        IMERC | Oct 16, 2006 06:14am | #10
        another version of Celotex...
        change away..
        1. rez | Oct 16, 2006 06:27am | #11
          IMERC's favorite building material.
          Common trade name for the various manufacturers  same type of 'insulating sheating' is asphalt impregnated fiberboard.
            IMERC | Oct 16, 2006 06:29am | #12
            HAH!!!!!
          2. GOLDENBOY | Oct 16, 2006 06:38am | #13
            vertical siding, eh.
            IMERC | Oct 16, 2006 06:44am | #14
            not in my life time..
          4. GOLDENBOY | Oct 16, 2006 07:30am | #15
            Guess I should elaborate a bit.  Vertical siding is just asking for moisture problems isn't it?  Water just loves to soak in to those little cracks and get behind the siding.
            I also so regular posts about running roofing felt vertical.  Why waste your time?
            IMERC | Oct 16, 2006 07:35am | #16
            verticalely sided houses are gold mines in disguise...
            for the reapirman...
          6. jesse | Oct 16, 2006 06:49pm | #17
            Around here that stuff is labled Bilt-Rite (I think).Anyways, we call it Built Wrong.
          7. DanH | Oct 16, 2006 07:05pm | #18
            Actually, the stuff isn't all that bad. It's really quite strong (though I doubt that it would count in a shear wall), it's cheap, and it does provide a modicum of insulation. When thoroughly stapled it seals tighter against air leaks than foam or OSB (but nowhere nearly as well as housewrap). The biggest negative is that, like foam, it's not a nailable surface for hanging vinyl, which is why you don't see it nearly as much any more.
          8. rez | Oct 17, 2006 06:29pm | #21
            I believe the listed R on a 1/2 inch thick board is 1.3when in doubt add garlic
          9. 2leftfeet | Oct 17, 2006 02:00pm | #19
            I think the only reason this place has not had problems with water (except around the crappy windows) is that it has nearly 3 feet of roof overhang on 2 sides, and a 6 foot wide wrap around porch on the others. It can be raining buckets and very little water is actually hitting the siding.
            However the siding is 30 plus years old and is probably at the end of its life so I will have to replace it soon.
            Thanks for the help.
          10. poo121 | Oct 17, 2006 11:27pm | #26
            looks like T1-11 blow and go sidding
    jagwah | Oct 16, 2006 05:01am | #7
    celotex
    an oiled surface fibreboard still used, used it on my own shed
