We have a sort of slow drain in our basement, mostly from a 30 year old toilet and it being right above the sewer line. If I put in one of those line pressure toilets, what happens when you flush and there is a backup? I dread the posts I will get on this one. Yeesh.
From durability to energy efficiency, continuous exterior insulation is an accessbile approach to a high-performance wall.
What can't go down.............
must go up.
In spite of the plumbers adage.
http://www.quittintime.com/
Why is your toilet constipated? Just age? Clogged artery?
Pull that sucker out, check the flow of the line, the vent function and put in the new one.
Bombs away!
I think the sewer is ok, I think the problem is the tank does not drop quick enough through those old holes to start the siphon fast enough.http://www.etherhuffer.typepad.com
Could be the wax ring has lost its seal.Troy Sprout
Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it."-- Thomas Sowell
And here I thought that toilets were supposed to be connected to the sewer.
Now I gotta go back to school. :)
BTW, in fourth year, you learn that given enough pressure, it WILL flow uphill.
Get a Toto and be done with it.
How about the new whirlpool super typhoon line pressure 0.1 gal per piddle models :-)http://www.etherhuffer.typepad.com
Isn't that what the Lone ranger said?
I once worked for an insurance company. We had one claim where a toilet was installed on a slab floor on one side of the warehouse and the waste line was run overhead across the warehouse to the sewer. They used a pump to get the blackwater up and over. As the women had a tendency to flush Tampaxs, etc., the overhead line plugged where it hit the main line. The pump just kept pumping away until the pipe blew. There were Tampaxs, paper, and ... well, blackwater all over the warehouse. It didn't hit the fan, but just about everything else.
The insurance company paid on the loss of merchandise without bothering to inspect it...
EEEEEWWWWWWW!http://www.etherhuffer.typepad.com
If it has been working in the past the vent stack could have something blocking it.
Make sure the vent is clear
