and where do I get more info on them. I have a grilled opening that must open inward for cleaning and ventilation. Any suggestion. Opening is 24″X 36″ high if that helps….
Listeners write in about HVAC company consolidation and stains from supply lines and ask questions about Larsen trusses and insulating stucco houses.
hopper window, as in basement
http://www.quittintime.com/
zooey,
"Hopper" as cal said.
Many window manufacturers make them.
http://www.harveyind.com/product_info/vinyl_new_construction/basement.asp
Maybee Transom.
You get out of life what you put into it......minus taxes.
Marv
If they're made with rabbets they're called hoppers.
Edited 11/6/2007 8:08 pm ET by Hudson Valley Carpenter
LOL, I LIVE for posts like that!Only way it could have been better is I made it myself;)
I'd be worried about both of us, heading for rockers on the sun porch, but I've always enjoyed those myself, since I was knee high to to a grape Nehi.
Now that I know that there's a few of us on BT I'll leave that part of my mind in gear.
Edited 11/6/2007 11:25 pm ET by Hudson Valley Carpenter
Google for tilt-turn windows.
Common in Europe, rare in the U.S., they have a mechanism that allows them to swing in, as a small door, or when the handle is rotated the opposite direction, hinge across their bottom edge and tilt inside.
A large window company called Traco makes them in Cranberry, PA, up a little north of Pittsburgh.
Marvin makes them also.
what is a inward tilt window called?
In my house, it would be called broken!
they"re called "inward opening windows!"LOL
Hopper's or in industry specific language "Pull-in" ,
Fleetwood Windows in Corona, Ca (http://www.Fleetwoodusa.com) I am in the process of replacing all doors and windows in my house with their products. two of which are hopper's. All sizes are available. Two of mine are 11' x 18" ( 4 windows in a single unit) and a 8'h by 6' with 2 36" hoppers at the top. I can post pictures if you like. Their windows are beautiful but expensive. Finally, their delivery dates should not be relied on
