what is head cut for this shed rafer?
paulewog | Posted in Construction Techniques on December 2, 2006 02:27am
Hello all
Maybe I’m having a brain fart here, but is there a way to mathematically find the head cut for a shed rafter that ties into an existing pitched roof without using degrees? I have done it converting my 7/12 pitch(shed rafter) to 30 degrees and my main roof 12/12 to 45 degrees and just did the math with supplement angles. But lets say for fun I don’t have a speed square with degrees printed on or a protractor. Can I find the “pitch” for my head cut by just knowing the 7/12 and 12/12  rise over run for each roof?
I also remember a guy told me about the “double the angle and minus 90” but by my math that only works with the same pitched roof. A 7/12 coming in to a 7/12.
Any thoughts are great
File format File format
  1. user-124063 | Dec 02, 2006 04:14am | #1
    Put your framing square on the bottom of a 2x at 12 and 12. On the left side of the square make a mark at 7. Pivot the left side of the square down to the mark and continue the line to the top of 2x. Hope that makes sense.
  2. Framer | Dec 02, 2006 04:26am | #2
    The one is this drawing I made is a 5/12 and 10/12 combination. You just do the same thing using a 7 and 12.
    Joe Carola
      fengelman | Dec 02, 2006 06:01am | #3
      sweetI wish I didn't know now, what I didn't know then
      1. JoeBartok | Dec 02, 2006 06:20pm | #4
        Paulewog: You can solve directly from the pitches, multiply by 12 and the result is all ready for use on a framing square:
        Formula for Difference of Pitches.
        Supplementary: Formula for Sum of Pitches.
        The equations are easy to remember and you can often do the math without a calculator.
        For your roof specifically:
        (12/12 – 7/12) ÷ (1 + 12/12 × 7/12) = .416667/1.58333 = .26316
        Framing Square: 12 × .26316 = 3.15789, about 3 3/16 over 12
        Joe Bartok
        Edited 12/2/2006 10:26 am ET by JoeBartok
        Edited 12/2/2006 10:32 am ET by JoeBartok
        1. paulewog | Dec 02, 2006 06:31pm | #5
          thanks Joe C,and Joe B, and rpm inc. Makes total sense.
          I hope you guys know how valuable of a tool this forum is and you alls knowledge is, to us greenhorns.
          again thanks
          Pauly
          1. Framer | Dec 02, 2006 08:22pm | #6
            Paul,Another way to do it by math is subtract the lower pitch from the higher pitch in degrees and subtract that from 90° and that's what you hold a speedsquare on.45° - 30.26° = 14.74° 90 - 14.74 = 75.26°
            Pivot speedsquare at the top until it hits 75° and that's your angle.Framing Square.14.74° Pitch is 3.157097" or 3-3/16"Hold the framing square at 3-3/16/12 and scribe the 12" side and that's your angle.Joe Carola
            Edited 12/2/2006 12:25 pm ET by Framer
          2. JoeBartok | Dec 02, 2006 08:25pm | #7
            For those who wish to do more research, the formulas in those links to the pdf documents I posted were actually modified "textbook" formulas.
            Analytic Geometry: Angle between Intersecting Lines, where m1 and m2 are the slopes of the lines.
            Trigonometry: Sum and Difference of Tangents, where tan a and tan b are the tangents of the angles.
            Since pitch = slope = tangent of an angle = rise/run, I took the standard formulas and substituted the pitch.
            Joe Bartok
            Edited 12/2/2006 12:26 pm ET by JoeBartok
            Edited 12/2/2006 12:27 pm ET by JoeBartok
          3. Framer | Dec 02, 2006 08:43pm | #8
            Paul,Here's a link to a thread about this a couple years ago. I showed how you can also do this with a speedsquare. That was with a 5/12 and 12/12 pitch.http://forums.taunton.com/tp-breaktime/messages?msg=49588.51Joe Carola
        McDesign | Dec 02, 2006 09:56pm | #9
        Against the wind . . .
Outdoor Lighting
  • A Grand Rescue on the Coast
