What is standard microwave installation for over the stove …
DoRight | Posted in Construction Techniques on January 1, 2015 04:22am
What is teh standard installation for teh electricl for a microwave over the stove?
1.  Most or all microwaves are of the plug vereity and not hardwared ?  Correct?
2.  Teh outlet is usually inside of a cabinet above teh microwave?  Correct?
3.  When installing this outlet is teh box mounted more proud of the stud than the standard 1/2 drywall allowance and then teh cabinet back is cut out?  Correct?
Pretty basic, but …
Thanks all.
    deadnuts | Jan 01, 2015 08:12pm | #1
    wing it
    Our electrican usually justs roughs the feed wire through drywall. Then at electrical trim out phase he (or we) cut in a wing box. This way the box is sure to be flush with the cabinet back.
    1. DoRight | Jan 01, 2015 08:59pm | #2
      Sounds good, but
      Is teh electrical inspector good with a wire hanging there?  Is it ok because teh electrial inspector comes back for a
      "final" after teh microwave is set?  I am not familar with teh inspection process.
      1. DoRight | Jan 01, 2015 09:07pm | #3
        Wow that is alot of teh (s)
        teh(s) sorry.
          Mike_Mahan | Jan 01, 2015 11:07pm | #4
          You're just trying to provoke Taunton into providing a spell checker.
          1. DoRight | Jan 01, 2015 11:12pm | #5
            ya tht si it exacctli.
  2. junkhound | Jan 02, 2015 12:02am | #6
    The one I installed has a recessed outlet box in the wall behind the uwave.
    Son's house that builder apparently did is in cabinet above the uwave. Big pain and interference with storing stuff.
    If ya gotta choice, recessed box in wall behind.
    1. DoRight | Jan 05, 2015 07:15pm | #7
      Recessed?
      You mean one of those specialty boxes people use for say a clock? It has its own housing and room for teh plug head? For teh microwave do you need to plan for a channel for the cord or is there enough room to squeze teh cord behind the microwave?
      so far a helpful thought. thanks
      1. gfretwell | Jan 05, 2015 11:56pm | #8
        Usually you need to leave a little room around a microwave so it can breathe anyway.
        1. DoRight | Jan 06, 2015 08:13pm | #9
          Heavy ?
          Do they breath heavily? I like that kind.
          1. gfretwell | Jan 06, 2015 09:50pm | #10
            Anything that gets hot that fast is uaually a heavy breather.
