Hey all,, plz suggest a good hinge jig. Any article on this? thanks in advance.
The all time best was what we called the Rockwell Door Jig. Made a long time ago, but possibly available second or third hand now. Adjustable rods to hold the templates together at certain distances. Great for production hanging. Porter Cable was their later company name. Here it is among others.
https://goo.gl/images/jCcNe6
Porter Cable had an individual plastic template. Spacer bars to adjust for hinge size. Tacked on edge of door or jamb. Came with a bit with bushing.
https://www.rockler.com/porter-cable-door-hinge-template
or
checkout rockler or lee valley.
or
you can make your own out of plywood and 1x2. Good enough when you want to copy to door from existing hinges in jamb.
Depends on how much you use them.
I've got a B&D set now that is fairly easy to use and performs well. But, if I were doing production finish work I'd use fixed templates. You need different ones for different hinge and door sizes, but they're really easy to use and perfectly accurate. They are made from plywood with a laminate veneer. Every door done with these comes out exactly the same. I used to prehang door for the local lumber yard and these were what I used.
yeah...
I've always prefered making plywood jigs over the factory ones myself. Even the fancy store bought ones take some tme to adjust
and also have a learning curve. Come to think of it the plywood ones have alearning curve too, just different.
Couple more thoughts
Unless you use them all the time you need to refresh your memory every time you do (with any jigs). If i were doing a lot of work I'd use my adjustables to make plywood jigs. I don't understand using a big router to do hinges. If I'm trying to fit a new door to an existing jamb, I'll always do it by hand; rout the center of the cutout by eye and finish with a chisel.
Metal Garage Buildings Kits
SPAMICIDE
F-ing stupid.
Are you so stupid that you put this spam in a completely unrelated thread or are you just trying to hide it so it won't be deleted, in which case no one will see it anyway?
Are you saying the jig is up?
Hinge jig
I have also found an article, you can see it
http://slickdoor.com/best-door-hinge-jig/
Hi Fred,
I reviewed a number of jigs for the magazine a few years ago. Personally, I much prefer the Templaco jigs to the adjustable type, but it will partly depend on the type of jobs you're using the jig for. Could you give some more details about your use?
Kit
