What is the correct terminology for this?
LoCisco7 | Posted in General Discussion on April 14, 2021 12:21pm
I have some wood that appears to seal where the sides of my house meet the foundation. It has rotted through and I ended up knocking it off while trying to weed eat around my house. I want to try and replace it myself but need to do research on what materials I will need. Can anyone provide me with the correct terminology to research? Is this just trim? or would it be considered a specific trim like water table trim?
Please see the pictures I have attached.
Thank you very much for looking at my post! 🙂
  1. florida | Apr 14, 2021 04:50pm | #1
    It looks like it was just nailed on top of the stucco. I'd use some PVC to replace it.
  2. firedudec56 | Apr 15, 2021 06:46am | #2
    possibly 1x flat stock used as trim - going to guess that it's about 4 + inches wide and about 3/4 inch thick, so that makes it probably 1x5
    as previously mentioned, use pvc flat trim - it'd work a little better with a bevel (maybe 15 - 20 degree) at the top to help shed water away from the building - the flat top allow the water to drip onto either side
    good luck
