What Is the pH of Drain Cleaner?
johnbruce1 | Posted in General Discussion on March 20, 2025 02:41am
Hey everyone, I’m curious about the pH level of drain cleaners. Are they acidic or alkaline? What is their usual pH range?
Also, how does the pH level affect their effectiveness in clearing clogs? Which type is safer and better for home use?
Looking forward to your insights. Thanks!
    user-1116674910 | Mar 20, 2025 12:40pm | #1
    Most drain cleaners are alkaline made with sodium hydroxide, with a pH of 14.
  2. damon780 | Mar 21, 2025 06:00am | #2
    Interesting question! The pH of most common drain cleaners can vary depending on whether they are acidic or alkaline. Typically, alkaline drain cleaners have a high pH, usually around 13-14, as they often contain sodium hydroxide (lye). On the other hand, acidic drain cleaners have a much lower pH, usually around 1-2, and may contain substances like sulfuric acid. Always use caution when handling any type of drain cleaner and ensure proper ventilation and protective gear.
  3. JacobHoward | Mar 22, 2025 06:25am | #3
    Most drain cleaners have a very high pH, typically between 11 and 14, as they are strongly alkaline. This helps break down grease, hair, and other clogs. Acidic drain cleaners exist too, but they are less common. Were you asking about a specific type?
    1. calvin | Mar 22, 2025 04:30pm | #4
      Often an A-eye post is made. Above, a plumber “appears” to be asking the question.
