what is this??
TomMGTC | Posted in Tools for Home Building on March 20, 2005 10:40am
Dunkin Donuts cup????
Tom
Douglasville, GA
  1. homebaseboston | Mar 20, 2005 10:43pm | #1
    LOL!!
    Technically it's a 3 week old dunkin donuts cup.
    _____________________________
    HomeBase______________  LLC
  2. Notchman | Mar 20, 2005 10:50pm | #2
    Why doesn't your tablesaw have a guard?      :-)
  3. Piffin | Mar 20, 2005 10:57pm | #3
    I've never seen eanything like it, but it looks like it could be used to drive unde one shingle to remove the nails in the undelying one as we do now with strippers.
      Luka | Mar 20, 2005 11:40pm | #4
      Looks to me like you would put the teeth up under a shingle, then rock it up to raise the edge of the shingle to get access to the one underneath.The curved piece above the teeth would keep the shingle you are lifting from breaking. It would bend instead of break.
      The person you offend today, may have been your best friend tomorrow It is easy to be friends with someone you always agree with.
      BillHartmann | Mar 20, 2005 11:45pm | #5
      I wonder if it is somekind of "twicker".You have the teeth that can grab into something (wood?) and then the curved base that you bend it over.Or the teeth mounted in the center or is one whole side of the open.I am thinking some to do with a flat leather belt, but don't know what.The curve part could be some kind of tensioning.
  4. dinothecarpenter | Mar 21, 2005 01:00am | #6
    The hole in the center indicates and the V teeth must be for nail removal.
    under shingles,flooring,slate?
    I bet on piffin. Or if you can find a use for it, better yet.
    You invent a use for a tool. Imagine that.
  5. Dave45 | Mar 21, 2005 01:04am | #7
    Looks like a Dunkin Donuts cup - probably from the early 21st century.
  6. 4Lorn1 | Mar 21, 2005 01:17am | #8
    Used to gently bend a asphalt shingle to insert a replacement and nail it in. Also after stripping a roof with the regular tools, long-handled shovel or dedicated remover, some roofing nails get left behind and that unit speeds removing the dozen or two that got left behind. Likely pretty handy for smaller roof sections also.
    Both of these are WAGs, as an electrician what the hell do I know about roofing other than they seldom last as long as they should and they often leak. My knocking a bloody great hole in them getting my riser through has Nothing to do with it.
  7. SCFrankland | Mar 21, 2005 01:19am | #9
    You got the wrong cup for starters.  You need to get a slushie cup for the shaved ice that the plane would make.  Also water from the ice will rust your table saw top so it is best used somewhere else.
    Scott C. Frankland
    Scott's WOODWORKING Website
    "He who has the most tools may not win the race of life but he will sure make his wife look like a good catch when she goes to move on."
    1. Pierre1 | Mar 21, 2005 02:23am | #10
      Actually, Scott, that's an official EZer D-Mix cup.
      1. SCFrankland | Mar 21, 2005 03:02am | #11
        You have to forgive me all I ever see around here is Tim's.Scott C. Frankland
        Scott's WOODWORKING Website"He who has the most tools may not win the race of life but he will sure make his wife look like a good catch when she goes to move on."
        1. Pierre1 | Mar 21, 2005 03:16am | #12
          I rolled up the rim on a double-double and won a doughnut last week!
          1. SCFrankland | Mar 21, 2005 03:34am | #13
            Ha I did better than that and won a muffin.Scott C. Frankland
      2. blue_eyed_devil | Mar 21, 2005 06:22am | #16
        I don't think so Pierre! That cup is too big. Or too small....
        Oh hell, I don't know...
        blueJust because you can, doesn't mean you should!
        Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
  8. donpapenburg | Mar 21, 2005 03:47am | #14
    I beleive that your guess is right, an Ice shaver . For the big blocks so that they could fit in the ice box.
  9. DThompson | Mar 21, 2005 04:35am | #15
    It was used to scrape the junk out of the eave trough.
  10. User avater
    JeffBuck | Mar 21, 2005 06:32am | #17
    well I'm way off ..
    I was gonna guess DeWalt table saw ...
    anyways ...
    wonder if it's some sorta "stretcher" .... could the teeth grab a strap of leather or wide caining? Then be stretched over or around something? I've seen similar looking tools for furniture making.
      Buck Construction
       Artistry in Carpentry
            Pgh, PA
Old House Air-Sealing Basics
