Hi All,
Does anyone know what this device is called? I’m told it was used for timber framing to drill the holes for pegs.
Thanks in advance,
Bob @ Kidderville Acres
A Woodworkers mind should be the sharpest tool in the shop!
Hi All,
Thanks in advance,
Traditional lime wash still has tons of useful applications.
Thats correct- it's a beam drill. Also used to take out most of the wood in large mortices- then square off with a chisel.
Thanks a lot. Wasn't sure of the correct name. I'm trying to find any historical info. I can for a friend of mine who owns it. Also trying to get Roy Underhills (Woodwrights Shop - PBS) email address.
Regards,Bob @ Kidderville Acres
If Roy sees that, he might bust a nut. That is right up his alley. Then again, he probably has 5 of them already, each for a different beam size.“The richest genius, like the most fertile soil, when uncultivated, shoots up into the rankest weeds..” – Hume
These are the folks that put Roy on the air:http://www.unctv.org/The show used to be done here, in Chapel Hill. I've met Roy a couple of times, pretty cool doode. "But to be honest some folks here have been pushing the envelope quite a bit with their unnecessary use if swear words. They just put a character in to replace a letter. But everyone knows what they're saying." Sancho
check out Eric Sloane's books on history/tools/wood - he addresses such things well -
the drill you have is a relatively late developement in timber framing - post civil war era - an improvement of simple augers because of the adjustibility -
"there's enough for everyone"
It's a James Swan Beam Drill!
Found it on a WEB Site for antique tools.
Thanks for your help,
I have one at home - I thought they were called a "post drill".Never have tried it out yet.
Half a truth is often a great lie. [Benjamin Franklin]
I'm sure there are a number of local names associated with them - probably the only 'official name' would be what appears on the patent application - -
you ever try to use one?
gawd, it's a lot like work -
might be better on green wood (bound to be, I guess)
I think these fancy mechanisms became popular because someone who know what he was doing could set them up, and then turn it over to a grunt -
Never have tried one, but I have no doubt it would be a lot of work. But - I don't think it would be any more strenuous than using one of the augers with a wood handle stuck through it. I've always wanted to catch a timber framing demo sometime. But there never has been one anywhere near here that I know of.
If you would be loved, love, and be loveable [Benjamin Franklin]
Hey! you have a tapered bung borer too. Ever use it? Makes good sockets for chair/bench legs ( large ones) I also have a tapered spoon for windsor sized work.
The secret to a long life is knowing when its time to go. M. Shocked
actually, we used to use the bung borer for just what it was designed to do - back when we handled cider in barrels -
