What kind of elec. outlets should I buy?
paulc127 | Posted in General Discussion on January 16, 2004 06:08am
I need to replace all of the electrical outlets in my house. (According to the wife, they’re the wrong color,) Also they are very loose and don’t really hold a plug well.
Anyway, does brand matter? Also, is there anyplace to buy online in bulk?
Thanks in advance.
Paul
  1. WayneL5 | Jan 16, 2004 06:36am | #1
    Not so much brand as quality level.  The major manufacturers each manufacture several quality lines.  I'd stay away from the bargain outlets.  A quality outlet is not that much more (less than whatever -- a cup of coffee -- pick your metaphor).
    If you get the higher priced of the outlets offered in a store you are probably fine.  One feature to recognize is the metal strip that forms the ears is continuous from one end to the other, running down the back of the outlet, providing support.  If you go to the counter of an electrical supply house, they can show you the various outlets and explain what makes one better than another.
    Don't use the press fit connections on the back of outlets.  They are not reliable.  Take the extra minute to form the wires properly around the screws.  A really high end outlet may have back connections that are not press fit, but secured by tightening screws on the sides after inserting wires through the back.  These outlets are on the high end of price but electricians like them because they are fast to install, and high quality.
    If you go to an electrical supply house and buy in box quantities they should give you a fair price if you ask.
    1. 4Lorn2 | Jan 16, 2004 07:09am | #2
      Value is typically in the middle of the market. It is, IMHO, so in so many things. Avoid the most and the least expensive. If you only had enough to buy a few higher end units locate these in the most used locations. Kitchen, shop and bath come to mind as often used and abused receptacles.
      1. gdavis62 | Jan 18, 2004 06:08pm | #35
        Go to an electrical supply house, and ask to see the difference between "regular" or "economy" grade and "spec" grade.  Ask to see "spec" in residential and commercial.
  2. paulc127 | Jan 16, 2004 07:30am | #3
    Thanks for the informaton. I  think I'll go to an electrical supply store and ask for a high quality unit. I only need 30-40. Not cheap, but it won't break the bank.
    Thanks, Paul
  3. bake | Jan 16, 2004 07:48am | #4
    For a decent, inexpensive home grade recepticle I ask the boss to stock Levingtons. We have tried many others but they just never measure up.
    1 opinion
    1. 4Lorn2 | Jan 16, 2004 09:20am | #5
      I have enjoyed using the 'Passe Seymour Legrande' line, not that there are not others. A bit more than cheap but I have had good experiences installing and maintaining them. Solidly constructed, reliable, won't break the bank.
      Mid and low end Leviton I'm less impressed with but I can't say don't seem to give good service if installed with a little care. I have been known to crack a few if I get in a rush and horse down the screws.
      Cooper mid grade is good. I have less experience with them, supply houses don't carry them normally, but they seem a bit better than Leviton.
      Eagle. Round here Eagle was only available at the big box and in the low grade. Not impressed. Seemed cheap, stripped screws and a few obviously defective, but in low use spots, The HO bought them, I can't say I've had any great number of callbacks. We took extra care to be nice to them during install. I hear their mid grade may be better.
      Of course all of these manufacturers have lower and higher grade lines so comparisons are within common grades.
      Any receptacle will give better service if well installed and supported properly. Don't hang the devices off the cover plate. Also avoid push-in type back wiring. The clamp type is probably as good as wrapping the screw, the time honored method. IMHO no single cause of problems is greater than the use of push-in wiring.
      1. glatt | Jan 16, 2004 04:53pm | #8
        "IMHO no single cause of problems is greater than the use of push-in wiring."
        I've read this on Breaktime several times.  If this is true (and I've heard it enough here to beleive it's true) why do the manufacturers and the code allow the push-in wiring?
        I replaced a bunch of outlets in my home.  Most I used the screws, but on a few, I back stabbed the wires because it was fast and easy and I thought it was OK to do.  Now I'm wondering if this is something new for me to worry about?  Should I go back and find which outlets I did this to, and re-wire them?  Or just leave them alone since they seem to work fine.
        Why do they make outlets with the back stab push in connections if they aren't as good?  Wouldn't the outlet manufacturers want their products to perform well?  Wouldn't they want to avoid the liability of making a product with a design flaw that could cause a failure or maybe burn down a house?
        1. UncleDunc | Jan 16, 2004 07:18pm | #10
          Because they reduce the labor cost for installation, and because not enough people have died in the resulting fires yet.
          1. skipj | Jan 18, 2004 05:17am | #28
            uncle dunc,
            Your absolutely right.
            As to 'why save a few bucks?':
            Save $1 per switch or receptacle on say, 120 per unit, on 1,000 units...
            Bingo! $120,000.
            The developer has left the building.
            skipj
          2. 4Lorn2 | Jan 18, 2004 05:32am | #29
            Exactly.
          3. fireball | Jan 18, 2004 08:08am | #30
            You probably shouldn't waste money on the best paint or brushes either then.Look at what $3 a gallon would add up to.And,if you're just going to walk on the floor anyway,why spend the bucks on hardwood flooring or ceramic tile when you can get vinyl squares for  88 cents?
            You get what you pay for.Televisions and vacuuum cleaners will wear out cheap receptacles a lot faster than the 50 years you say you've seen them last.
          4. 4Lorn2 | Jan 18, 2004 01:18pm | #31
            Different cost / Benefit ratio. Different analysis.
            As far as paint goes I'm no expert. I can say that Consumer Reports has done some testing that I have read about. Their conclusion indicated that many of the most expensive paints fared no better than some discount lines. If I remember correctly their top paint, at least once, was a moderately priced paint from a big box. I only remember this report because it, once again, supported my view that value is in the middle of the market no matter what your buying.
            To this particular case. The vacuum may cause more wear than a clock radio simply because it is plugged and unplugged frequently, several times each usage but seldom more than once per use in any one receptacle. The TV much less so. Smaller load much less frequently moved.
            You can spend as much as you can talk the customers into or, more likely, your boss is willing to finance and sell. Many customers won't stand for too many $20 receptacles without a good reason. Customers are seldom impressed by getting 'the very best'. They just want something that works well, looks good, lasts a reasonable amount of time and won't drastically increase the cost of the home.
            Consistent overbuilding can kill a business by lowering profit margins. On the other side the same is true if you install too many devices not up to the task at hand. Call backs are expensive.
            In competitive markets a consistent but small reduction in profit margin, from overbuilding or call backs, can, over time, break a business. In hard times many electrical contractors live on the financial edge. They must daily perform a balancing act.
            Contrary to your understanding of what I posted I am not advocating using substandard, cheap or units not up to the job they are called to perform. A carpenter would not use rosewood or birds eye maple for duck boards over a puddle. A mason does not use expensive imported marble tiles to line a dry well. An electrician should not waste a customers money installing a receptacle suitable for the space shuttle. Not when a device a tenth the cost will outlast the house.
            I am advocating a balance because the platitude of 'using only the very best', as opposed to something 'more than adequate for the situation', is wasteful and foolish. Business is all about getting the most bang for the buck. Providing value added products that customers want, ones that will provide differences that they can sense, care about, and ones that they are willing to pay for.
          5. greggo | Jan 18, 2004 03:21pm | #32
            Hey is any body using those premade pig-tales with the crimped ends that I keep seeing at the supply house??
          6. 4Lorn2 | Jan 19, 2004 01:19am | #38
            Those premade green pigtails are popular with systems run in conduit and where there are a great number of metal boxes. I have never seen them used in any great numbers in Romex cable, NM, systems and where plastic boxes are used.
          7. greggo | Jan 20, 2004 01:12am | #41
            Thanks Lorn: I seen them and was just curios
          8. gatno | Jan 20, 2004 05:10am | #42
            Gimme a choice, and i`d never choose phillips-head contacts instead of robertsons (square-drive, eh?) for any of my electrical stuff--and you won`t find robertson heads on the cheepy units, either
          9. greggo | Jan 20, 2004 06:23am | #43
            Rod: not sure if we are on the same page.I was wondering if premade pigtails were that much faster than reg.hand made
            Stay Safe
            Greg
          10. marv | Jan 19, 2004 08:41pm | #39
            premade pig-tales
            I used some donated ones on a Habitat house.  After you get used to them, they work great.  The problem comes when you have multiple wires coming into a box, and the nut won't fit over all the wires.  Then you have to pig-tail.  If you buy them, do not get the stranded without connectors on the ends for outlets.  Connecting stranded directly to outlet is a no-no in my book.You get out of life what you put into it......minus taxes.
            Marv
          11. greggo | Jan 20, 2004 01:09am | #40
            Thanks Marv: I was just wondering if they were that much faster.I don't mind spending a little more if it speeds things up(not that making pigtails is all that hard),but when you are doing everything in a house by yourself anyway I can save some time helps
          12. rasconc | Jan 18, 2004 09:33pm | #36
            You are so right.  Better is the mortal enemy of good enough.  I find myself pointing out items that are " a little bit or quite a bit better" to a customer who often says they want it.  Later when all the "littles" are added up it becomes significant.
            Matching the material to the task at hand or reasonably foreseen is the right thing to do.  If customer has the resources and desire you can play "how much can we make this cost".
            Properly installed most receptacles will last a very long time unless subjected to abnormal abuse.  If you shove the filing cabinet into the wall even the best will probably break.
          13. fireball | Jan 18, 2004 11:42pm | #37
            No one has suggested using hospital grade receptacles(the twenty dollars you like to quote?) here.What we're saying is that using the good commercial grade receptacle from a given manufacturer, that might cost 2 bucks a piece more, is money well spent.It's not "overbuilding" for "titanium houses"or "space shuttles" or whatever exaggeration you can come up with.In $30 an hour labor markets, two bucks a receptacle isn't anything.The original poster here justs wants to know a good receptacle to buy,I don't think he cares how Pulte Homes greases its bottom line.
             While most of the electrical system in a house is unseen and untouched by the average homeowner,receptacles have to sustain the wear and tear of people's use and abuse,and so shouldn't be a weak link.I'm saying that to use the house brand of 15 amp residential receptacle is false economy.When you say that you've seen 39 cent receptacles last 50 years you're encouraging people to be cheap.
        2. NormKerr | Jan 16, 2004 08:32pm | #13
          One really big way to improve the safety of a back-stabbed outlet installation is to make sure that at least the outlet is pigtailed and not in series with the other devices on that circuit.
          This means that the only power in the back-stabbed outlet is the power consumed at that ONE outlet, not all of the power on that breaker/circuit (including all of the down-stream devices).
          Back stabbing is a very weak connection, only a thin metal blade is touching the wire at one point. Maybe ok when new, and when just used for a table lamp or something, but any resistance in that delicate joint will generate heat (and the more power going thru, the more heat generated). Pigtailing means that the main power feed passes thru the box, and the outlet is just a branch off that line, VERY important if downstream devices could be hair dryers, space heaters, window mount airconditioners, vacuum cleaners or any other of a myriad of today's large current consumers.
          Using the screws and getting as much surface contact, under a tight screw, makes a very durable, and very sound connection. Doing this with a pigtailed circuit is the belts + suspenders way that any good electrician will insist on for all of his jobs.
          The best solution for convenience is the high end type of outlet, with screw-tightened, rear wire design. As easy to use as back-stab, but still a secure joint because its captured by a screw like the connection at your circuit breaker. This kind of device is also very durable because the materials of the housing and internal connections are generally higher grade, so they tend to hold up better to heavy use.
          Since the cheapo outlets cost $0.25 or so, and the high end cost $3.50 or so, the cost difference may matter if you're building a 100 home tract, but to most consumers the cost difference is easily overcome by the quality (I think).
          Hope this helps,
          Norm
          Edited 1/16/2004 12:33:29 PM ET by Norm
          1. glatt | Jan 16, 2004 09:54pm | #14
            "Hope this helps, Norm"
            It does.  Thanks.
        jonblakemore | Jan 16, 2004 05:09pm | #9
        4Lorn,
        What do you think about Hubbell's?  I read Rex Cauldwell's book http://www.taunton.com/store/pages/070639.aspand he recommends the Hubbell outlets as being the best of the best.  I think they're $20+.  Is there any merit to something this expensive, or are these a result of high-end spec sheet follow the leader?
        Jon Blakemore
        1. DaveRicheson | Jan 16, 2004 07:26pm | #11
          I use Hubbels all the time. They are good, but like other mfg. have different quality levels. I have never paid $20.00 for a standard duplex Hubbel receptical, but have for some of the twist-lock types.
          I have also seen Hubbels broken from abuse and improper installation. As 4Lorn says, a liitle care and attention durring installation goes a long way toward the devices' safe use and life.
          Dave
            Gunner | Jan 17, 2004 08:02pm | #24
            I'm definatley a hubble man as far as commercial goes. I didn't know they made aresidential line.Who Dares Wins.
          2. DaveRicheson | Jan 18, 2004 02:19am | #25
            They may not. I buy most of my stuff from a supply house, and spent very little time in the electrical isle at HD or Lowes.
            I can call the supply house, place an order, then pick up on the way to a job or home, Might take 15 minutes out of my day. Takes me that long to park, walk in and find the right isle at a big box. If I have guestion, my supplier has a staff that can answer, not some old retired fart or snot nosed kid making a WAG at the big box.
            BTW for those that haven't cracked open a recptical lately....try it. In fact try a couple. I think most of you will be supprized. Although many look alike outside, the inside is where the real differance lies. Rivets, spot welds, clamps, and bus seperation partitions vary all over the place.
            I still have quite few to go, but I intend to crackem open everytime I get one I haven't done yet. So far I've seen Pass Seymore spec. grade and a Hubbel.  Both 20 amps. Got a few different one laying around the shop I think I'll whack tomorrow.
            Dave
            Gunner | Jan 18, 2004 02:29am | #26
            Who do you use? Most suppliers in Louisville are pretty good. I'm always looking for more though.Who Dares Wins.
          4. DaveRicheson | Jan 18, 2004 04:28pm | #33
            Russel Electric, aka Peterson Electric. Peterson bougth out Russel several years ago, so my account automatically rolled from Petersons to Russel also.
            Nice thing is now that I work downtown all the time now, I am only one block from Russel. If they don't have what I need, it can be delivered from Bluegrass the same day. I still get the suport from the staff at Petersosns' Bluegrass location.
            Dave
            Gunner | Jan 18, 2004 04:58pm | #34
               Yea I've been in there a couple of times. I bought some hard to find Westinghouse breakers from them last year. Seven hundred dollars for a dozen I think it was. But they had them. Then I swung in there last month for supplies. When I'm down in that area I usualy go to E&H around the corner from them. I'm a Peterson fan as well, they are really hooked up when it comes to hard to get or obsolete stuff.
              I was just over at fifth and Market Friday swapping out an ATM at the Stockyards bank main office. Someone has to go back and trim it out as we only had scraps to fix it with Friday
            Who Dares Wins.
            Edited 1/18/2004 9:02:26 AM ET by Gunner
          6. 4Lorn2 | Jan 18, 2004 05:08am | #27
            IMHO any of the receptacles sold by major major manufacturers, I exclude the no-name dockside imports with faked UL stickers, are reasonably good for a lot of residential situations.
            The fact is that if all you are going to plug into a receptacle is a clock radio and it will not be unplugged for a decade or more just about anything, even the 39 cent models, will give you good service and a long life. Your just not asking for much.
            I have seen some dirt cheap models that have been in service for over 50 years come out looking quite unblemished and ready to go for another 50. Unfortunately most of these were obsolete two prong models that were discarded during a remodel.
            With such requirements spending up to $25 for a super duty, corrosion proof, virtually bulletproof receptacle is pretty foolish. Most houses won't make it to 100 years without a major remodeling. More receptacles will replaced because they are painted into submission or the owned prefers a different style.
            To get the full benefit from you high dollar units you may have to have them removed and reinstalled into several homes. The cost of this service, moving the devices, will far exceed even the exorbitant cost of the units themselves.
            IMHO far too much attention is being paid to which is best and not enough to what is adequate, don't forget to add a margin for abuse or unusual conditions, and able to give good service in any particular situation. Given this logic houses would be made of titanium or ceramics and insulated with aerogel or vacuum bottles. You can go for the absolute best but not without a cost.
            Go too high on the 'best' scale, how high you wish to go is a judgment call, and you pay a cost that will never be returned in savings, cost reduction, convenience or performance. That is fine if your just made of money or are going for bragging rights but it is wasteful. I think there are better ways to live and spend money.
            A friend, long ago, gave me an adage which has served me well: 'Value is in the middle of the market'. Avoid the top and bottom extremes and you will find units, be it cars or electrical receptacles, that will give you good service at a reasonable price.
            You can get all one model of receptacle and use it in all the locations in a house but I find that most homes, and contractor bottom lines, can benefit from consideration of how a receptacle is likely to be used. Kitchen, bath, exterior, office and garage receptacles get used, and abused, the most.
            Most bedroom receptacles far less so. Especially if the electrician takes care not to locate receptacles behind where a bed is likely to be placed. A bed frame beating on a plug can destroy, in the passion of the moment, even the best devices. The $20 units last about two strokes longer. About 1.33 seconds.
            I usually go with one step over the lowest end units for the majority of the house and one step up for the high use locations. This, IMHO, gives the best combination of cost and performance.
        BillHartmann | Jan 16, 2004 08:21pm | #12
        Cooper now owns Eagle (and Arrow Hart).
        All devices that I have seen had both names on them between the device, the paging and the shelf tag.
        But when you say mid grade can you be more specific.
        Last month we got into the difference between 15 & 20 amp devices and I looked at some in the SAME GRADE LEVEL.
        These part numbers and prices are the same for both Cooper/Eagle and Levitron.
        CR-15/20's are the spec grade and run about $2-2.50. BR-15/20 are same but allowed for backwiring.
        #5252/5352 are the commercial grade and I think that they run about $4.00, but I really don't remember.
        Now both of them had the 39cent/10@$3.19 residental junk.
        And one of them had an upgraded residentail for a less than a buck. But as I was looking at the differences between 15&20 amp devices I did not look at them in detail.
        Also in a different thread last month (loose screws) you said "These movable plates are used to clamp solid wire, no stranded need apply,"
        I had never heard that about stranded wire.
        I would looking at Cooper BR-15 and BR-20 and Leviton BR-20's and 5252/5352's today.
        The Cooper's had marded on the back next to the holes #14-#10 AWG CU.
        The Leviton's had the same information printed inside the box.
        Neither place did they limit it to solid wire. "These movable plates are used to clamp solid wire, no stranded need apply,"
        1. DaveRicheson | Jan 16, 2004 10:42pm | #15
          We use stranded #12 in Hubbel, Pass Seymore, and Leviton commercial grade recpt. all the time. Same basic plate clamp configuration on all of them.
          You mentioned the differances you could see on spec. grade and cheapos. Back straping being the most obviouse, and metal guage next I think.
          As misfortune would have it, I had to replace a couple of spec grade P/S and one Hubbel 20 amp recpticals a few weeks ago. I found out the differance goes deeper than what you see outside. Al three devices had been crushed by file cabinets being jambed into cord plugs plugged into them.
          Looking at the hot and nuetral bus clamps, it was clear that the Hubbell was heavier duty than the spec. grade P/S. Back straps were pretty much the same except the Hubbel strap also connected through the center to the plate mounting srew hole. Ground screw was a heavier strap connection to the back strap on the Hubbel. Biggest differance was in the clamp tension. Hubbel out clamped the P/S because of the heavey metal and better spot welds holding the two parts together.
          I am not putting down the P/S, because the Hubbel happened to be one of the top of the line devices, and the P/S was only a spec grade. Both brands  got smashed pretty good, and neither shorted to ground on the metal cover plates or boxes. Pretty good testimonial to me. We would have never know of them being broken if we had not been doing an office renovation.
          Dave
            BillHartmann | Jan 16, 2004 11:24pm | #16
            I was not really doing a comparison between the grades (residential, spec, commerical) or between brands when I looked at these.
            The orginal discussion was to get "20 amp recpts because they are "BETTER" than 15 amp).
            My claim was that they are idential, WITHIN BRANDS AND GRADES, for everything that would affect the operation of a 15 amp plug. That includes all electrical paths along with the mechnical construction.
            I believe that people think this because they compare the 39cent 15amp residential to 20 amp devices which are only available in the better grades.
          2. junkhound | Jan 17, 2004 04:43am | #17
            Bill:  Even in the cheapos (which as you say do not occur in 20- A) there is a difference in that the inserts in the 90 degree slots on the 20 A outlets usually provide better plug retention.  I put all spec grade 20 A in my own house (and we only have 2 appliances with 20 A plugs) just for the better plug retention wit;h the ubiqitous 15 A prongs.
            Went to the basement storeroom and shot a pix of some outlets that may be a tutorial for novices, obviously only what is on hand and not a complete story:
            From the lower LH and counterclockwise (just to confuse)
            LLH group of 4 Hubbel outlets, the LH is a 20A face, the backs show typical configurations that are NOT push-in (none here are, God forbid!) but for screw clamps. The Orange is a Hospital grade outlet, non grounded frame.
            next is an H&H hosp grade back,
            next are front and back of Bryant spec grade outlets,
            upper4 LH is a group of 5 Leviton outlets, the fifth only has screw terminals, which is what is in my own house.  Would you beleive I fished the romex or THHN thru every box and ONLY THEN stripped the wires and srewed them down WITHOUT cutting the wires, simply strippe dthe insulation - inspector (this was 35 years ago) said he never saw such a thing, but was impressed I'd go to the trouble.
            finally are a couple of GE outlets, the last is a great outlet for special purposes, non-code now, but 4 ungrounded slot on one outlet! - still got a small stock of these <G>
            You may need to copy the pix to photo ed and brigthen, darken, etc to get details of each.
            BillHartmann | Jan 17, 2004 07:41am | #19
            "there is a difference in that the inserts in the 90 degree slots on the 20 A outlets usually provide better plug retention."
            I have been told my a friend of mine that the quality 15 amp devices have the same sidewiping contacts.
            When I did look at them at the store I looked down into the socket and as much as I could see the 15 and 30 amp appeared to be the same, but without the horizontal slot I did nothave as view of view on the 15 amp units.
          4. junkhound | Jan 17, 2004 09:06am | #21
            .....told my (by?) a friend of mine .....
            ..no offense, but don't rely on a 'friend' - smack a few apart with a hammer and look at the innards and you will see the difference .
          5. mosseater | Jan 17, 2004 10:55am | #22
            We use Leviton spec  grade all the time, back wired,with stranded(no pig tails) and have zero (0) problems. Levitons takes one hell of a beating without a squawk or wimper and just keep on going. Keep in mind this is an industrial environment with stupid-abuse reigning supreme. I tend to really crank my connection screws and have yet to strip one in 17 years. No fires, no meltsdowns, no shorts, no lost neutrals. I think they`re a fine product.
            BillHartmann | Jan 17, 2004 04:57pm | #23
            I agree, I should have given some background.
            These are long time online friends from Compuserve. One is a professional electrician.
            The other, while not a full line electrican, has a strong background in wiring, both residential and number of industrial applications.
            I don't remember which one said this, or maybe both.
            Based on the long term online contacts and they knowledge that I have seen from both of them I would not hesitate to trust either one.
        2. 4Lorn2 | Jan 17, 2004 05:51am | #18
          Re: "Also in a different thread last month (loose screws) you said "These movable plates are used to clamp solid wire, no stranded need apply,"
          Could have swore, a few years ago on a jobsite, that I saw a message pressed into the back of a receptacle. Something like 'solid only' but I don't recall the brand or model so it could have been a hallucination. I'll try to look at more of these units and see if I can find the mark or something definitive. I might get on the manufacturers sites or technical support.
          That said my primary motivation for the statement is primarily practical. Have you ever tried to stuff, in good order of course, a #12 stranded into a hole scarcely big enough for a #10 solid? While it would not be the end of the world if a single strand doesn't make it into the hole or doesn't get firmly clamped it does reduce the capacity of the connection. Increases the chance of it being the weakest link.
          Standard types, with a regular recessed screw, are also more difficult to use with stranded wire but any loose or uncaptured strand is much more visible and so more likely to be corrected.
  4. DocDM | Jan 16, 2004 10:41am | #6
    I'm no sparky, so I'll ask one to chime in. How old / what type of outlets are you replacing?
    Make sure you get the grounding right - I've gone into nightmare situations in older homes where homeowners swapped out two prong outlets with three prongers, but no grounding wire. Don't simply swap in the three prongers so your appliances can be plugged direct.
    Sparkies will explain more.....
    Doc
    A shortcut is the longest distance between two points.
    1. paulc127 | Jan 17, 2004 07:51am | #20
      The outlets I am replacing are 40 years old. I have been unable to determine a brand
      Basic two- receptacle ree prong  w/ proper ground
  5. MisterT | Jan 16, 2004 01:54pm | #7
    Spec grade outlets are a good quality Commercial grade at a reasonable price.
    It should say "spec. grade" on the package and styamped on the device.
    FHB did an article about wiring recently that went over this.
    Mr T
    Do not try this at home!
