What Nailer/stapler for 3/4 ash hardwood into 3/4 plywood over 1/2 plywood subfloor?
What nailer/stapler do you recommend and what size staples for 3/4 ash hardwood over 3/4 plywood and 1/2 subfloor?
In this FHB Podcast Segment, the team chats about the best way to build a paintable surface over an old wall.
John
I'd have to look in the shop for the correct staple size for your flooring, but I use a Bostich stapler or have used a portercable cleat nailer.
Hand driven, I've use I believe the name is PortaNail..............been a while.
You buying or renting? If renting, they should make sure you have the shoe for 3/4 flooring and then the corresponding length fastener. Usually you want to go through the subfloor, but yours is thicker and I think not necessary to do so.
Where's Ken Fisher when you need him?
I'm here now and then...but MIA for a month. More guys are confident with cleats nowadays because they allow for a more natural epxansion of all hardwood floors. I can't see the orginal post now, but 2" lengths work best for wood subfloors. Powernail, and that Canadian manufacturer I always keep forgetting are two additoional choices. Primatech is the name.
